Diagnostic Equipment
Discussion in 'Trucks [ Eighteen Wheelers ]' started by habfleet, Aug 20, 2013.
  1. habfleet
    habfleet Light Load Member
    163
    23
    Feb 5, 2012
    elwood nj
    Looking for any commets on the Noregon JPRO diagnostics I need something that will handle several diffrent makes of trucks and engines
    Thanks
  3. Rawze
    Rawze Medium Load Member
    328
    818
    Jun 29, 2013
    inmytruck
    I have the JPRO and noregon's software. I paid $2850 for it, and the adapter. GET A NEXIQ ADAPTER instead of theirs. Theirs is junk comparatively and is not compatible with several other softwares out there (believe me, you will need more than one piece of software to do most of the more serious things at some point, and you will also want a better adapter to go with it). I have used heavily all of them. Their software is pretty good and will work with the NEXIQ, but do not think for one minute it will actually help you solve EGR/DPF problems like they claim. It can show you the codes and that is about it. Its got lost of fancy-looking gauge screens and eye candy, making it look really fancy, but is only good for basic troubleshooting and/or clearing engine codes temporarily. Personally, I will never buy their products again because their software is just too finicky in its registration. Mine keeps loosing its registration and now they want several hundred to activate it again because my one year free support is up. If you do decide to get their software, dedicate a laptop,...a fast laptop (it hates slow laptops) to just that one software alone and do not use it for ANYTHING else,..EVER!. If their waay-to-picky software sees something change even slightly on the computer, then it will unregister itself and you are calling them on the phone to get it reactivated. Other engine software is not nearly as touchy, but their software has the advantage of being overall, more versed with many different types of engines for basic troubleshooting ONLY and code reading.
    Be forewarned, their software cannot change settings in engines, nor can do a forced regen, DPF reset, etc on many of the newer engines to get a truck going again after needing DPF cleaning. For this, you need that engines software and a decent adapter (not the JPRO).
  4. wore out
    wore out Numbered Classic
    17,440
    217,306
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    What he said, we use the snap on nexiq Iq with just the heavy duty standard software its basically useless. with manufacturer software it is a pretty good tool (no soft ware for cummins offered). I can't speak for the CAT software nexiq offers I dont have it I use CAT ET for all my cat stuff just got lucky and have an in
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Have you looked into PF Diagnose? http://www.pocketfleetdiagnosticsolutions.com/? It's about 1/2 the cost and has better suport. It also does a little more than JPRO. Keep in mind that no aftermarket software will do everything that OEM does. Get an idea of what you want to do before you shell out big bucks.
    We looked into JPRO and PF Diagnose. Neither could do injector trim codes, cylinder cut-out tests and a few other important things that we needed. Out of both, PF Diagnose would be my choice for basic diagnostics. JPRO had a lot of add ons/accessories that they wanted you to purchase separately. They also were tough to get info from, they'd answer questions, but offer no additional info. The people at Pocket Fleet went above and beyond and told us up front what it could not do. After asking them the same questions as we asked Noregon, I had many more questions for Noregon.
    In the end, we wanted to be able to change injectors and prgram the new trims as well as change some customer perameters that neither program could do, so we got OEM software for our 3 engine types.
    If you have Paccars with the multi-plexed systems that need Paccar ESA, it's about $800.00 and comes with a Nexiq USB link. That is cheap considering that the USB link is usually over $800.00 alone. So if you have Kenworth's or Pete's, buy that 1st and you'll already have a Nexiq for any other software you buy.
  6. wore out
    17,440
    217,306
    Jun 5, 2013
    I can do cut out test, trim codes, and cruise settings change top road speed etc with the nexiq
  7. GrapeApe
    2,215
    2,212
    Jan 7, 2013
    On Cat, Cummins and Detroit? What was the cost of the Snap-on? Is there a annual fee, or 1 time license? JPRO could not do newer Cat trim files, from what they told me, only older 4 digit codes.
    Also, can you do forced regens, Cat intake actuator tests, or HUEI pressure tests? Those were a few other things that it wouldn't do. Plus it couldn't change driver reward settings. I forget everything, but there was a lot the JPRO & PF Diagnose couldn't do. I didn't look into Snap-on's.
  8. wore out
    17,440
    217,306
    Jun 5, 2013
    Cat detroit and international it does most of that would have to verify each procedure. Cummins is heavy duty standard only code clearing and data list only a good mack program and others are available I don't have you buy programs sep if not all you have is heavy duty standard for the 4 programs I have cables and monitor and fault code guide was bout 6000 I think no yearly fee
  9. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    Great imput now I really don't know what to buy. I was suspious of JPRO thats why I put it out there.What about their claim that they will automatically go to a Mitchille (seperate purchase) program and guide you threw the diagonistics for what ever code your working on. I did have the NEXIQ and liked it but it seems they did not keep up with the times and no cummins programs. THANKS FOR ALL THE IMPUT
  10. Tea Bagged Ya
    Tea Bagged Ya Bobtail Member
    14
    5
    Aug 20, 2020
    TEXAS
    Any updates on this thread? Anyone using the Nexiq HD and if so does it work with the EPS software?
