diagnostic port location
Discussion in 'Trucks [ Eighteen Wheelers ]' started by elitetrucks, May 7, 2021.
  1. elitetrucks
    elitetrucks Bobtail Member
    Where is the diagnostic port on a Western Star 4700
  3. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Most of the time the ports are by the clutch pedal. I have never seen this model truck but I can tell you that some of the newer model trucks have switched over to a different port than the round Deutsch connectors.
  4. Goodysnap
    Goodysnap Road Train Member
    3,772
    9,197
    Jul 12, 2017
    Can you elaborate on this? Not questioning you but I am curious. Can you provide truck models, years and what connectors are used? I do know there are some models that use OBD2 automotive connections, but the unit in question also has a 9 pin.
    I was under the impression that US standard was the 9 pin Deutsch across the board due to OBD standards.
  5. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    I had a 2020 or 21 truck come in recently that had a odd rectangular connection. I can't remember what truck is was but will find out.
  6. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    2021 Western Star So that might explain why they can't find it. It is odd ball.
  7. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    OK was talking to the owner of that truck and turns out it it is just OBD connector. Sorry I had no idea that they would put that type connector in a new truck. Figured everything would be round now a days. So to the OP it is probably OBD2. Do you see something like this under the dash near clutch pedal?
      File size:
      209.1 KB
      89
