Did I pay too much for this clutch replacement on a 1998 Volvo
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Straight Diesel, Mar 16, 2026.
  1. Straight Diesel
    Straight Diesel Bobtail Member
    21
    24
    Jun 14, 2025
    Good morning everyone,
    So I had my Eaton clutch replaced recently and all my O/O friends are telling me I paid way too much. I too believe it’s too much for what you get, but here’s the issue.
    I have a ‘98 Volvo Eaton 13 Trans. I had a rear main seal fail and the oil saturation was burning out the clutch. I called 4 shops, 3 Arizona, 1 Las Vegas, NV. They all told me essentially the same thing “Volvo’s are much more labor intensive, 15hrs minimum.” They were saying this is because the transmission holds the motor up and they share mounts. I’m not a mechanic, but I don’t see how that makes it way more difficult. Long story short I felt I had to trust these people based on them all saying the same thing. Had to chose someone right? So I went with the Vegas shop. They replaced rear main seal, clutch, clutch brake (I supplied), slave & master cylinder, trans oil line, new turbo exhaust pipe, weld on other exhaust leak, clutch gear, a power steering line and had them reattached a hood latch that came loose.
    Flywheel was good.
    1’st quote $3,300
    Oh it’s a Volvo
    2’nd quote $4,000
    New discoveries
    3’rd quote $5,800
    Arrive at the shop
    $7,700
    I honestly didn’t know what to say when I saw that except after he said “it’s a little more than we discussed” I said it’s a lot more in which he responds yeah, a lot more…
    So I paid the guy and left and luckily had my most profitable week ever the 1’st week of January. Lucky me because that nearly broke me for the 3’rd time. Now I’m writing this on the side of the road because I somehow lost all the fluid out of my brand new Slave/Master Cylinder reservoir. Can’t find the leak and it’s a blizzard outside.
    Like I said all my buddies telling me they don’t care it’s a Volvo I doesn’t take that long or cost that much more.
    There you go
    Thoughts?
    Friend Thanks this.
  3. Big Road Skateboard
    7,217
    41,007
    May 2, 2021
    Your Volvo buddies have never replaced a Volvo clutch if they think it doesn't take longer. I'd say 15hrs is fair with a rear main.
    You didn’t say what the final breakdown on parts/labor, so we have no guess on the final #'s
    Bean Jr., AModelCat and Rideandrepair Thank this.
  4. Straight Diesel
    21
    24
    Jun 14, 2025
    It’s true they never have, they never had a clutch/transmission issue with the few that have owned one.
    What do you think about that price. All those parts were pretty good on price, it was the labor that killed me. They only charges $125/hr which is hard to come by today. I am a bit suspicious why it was almost $2,000 more than my last quote, but mechanics are notorious for bad communication. It was good up until that last quote.
    Rideandrepair Thanks this.
  5. Big Road Skateboard
    7,217
    41,007
    May 2, 2021
    No guess without seeing the bill. You added a few things there
  6. Straight Diesel
    21
    24
    Jun 14, 2025
    I’ll see if I have a digital copy of that, I just filed everything at home for taxes. Everything added up on it, it’s just a matter of believing it or not.
    What is you experience with transmissions on an older model Volvo truck?
  7. wore out
    wore out Numbered Classic
    17,438
    217,176
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Well let’s see if the rear motor mounts are on the rear structure of the engine when you pull the transmission it holds itself in place. When you push the transmission back in the engine stays in place.
    When the rear engine mounts are on the bell housing you have to support the rear of the engine plus going back is harder because the rear moves around. So why wouldn’t it be harder? Big trucks big bucks don’t like your bill? Learn to do it yourself. A good mechanic ain’t cheap and a cheap mechanic ain’t good. It’s obvious if a trained monkey could do it you’d a found one.
    Heavyd, AModelCat, rollin coal and 8 others Thank this.
  8. Straight Diesel
    21
    24
    Jun 14, 2025
    Thanks for the insight.
    I’m not complaining about my bill, just saying I was a bit blindsided by it. For the most part I like those guys and I have since used them for a PM service as my oil shipment wasn’t going to arrive in time. I’m mechanical, but not a mechanic. The most I’ve done was replace my injector wiring harness, so as far as transmission work goes that’s not something I’m going at alone especially with the knowledge it’s more labor intensive than the rest. I don’t have the equipment for it either, transmission jacks and such. You’re explanation sums it up I couldn’t picture it exactly before.
    Bean Jr. and Rideandrepair Thank this.
  9. ElmerFudpucker
    7,112
    77,834
    May 17, 2024
    We always got an extra hour for Volvo’s and Mack’s. Book rate was 10 for a Cabover, 11 for a conventional and 12 for Volvo and Mack. Least that’s how I remember it. If it has complete fairings and any after treatment or weed burner exhaust I can totally see it being a 15 hour job.
  10. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,201
    May 10, 2015
    Detroit, MI
    Clutch replacement in an old Volvo is the same as other trucks from that era, there is nothing special about it. Labor to do it was always around $1000 at my local shops.
    With anything extra price goes up. I would need to see the whole invoice
  11. 201
    201 Road Train Member
    12,826
    26,410
    Apr 16, 2014
    high plains colorado
    :eek:,,,I just don't know. The logical part of me says yes, as I did my own clutches for maybe a couple hundred bucks years ago. Vehicle repair has gotten so out of whack, it will take an act of Congress to get it back under control. My brother got a surprise bill on his pickup, replace 2 front brake hoses and a couple lines, $900 BUCKS! Your situation would have me buying a "For Sale" sign, cost, .98 cents, made in China,,,.
