Diesel engine oil shortage predictions, will it happen?
Discussion in 'Freightliner Forum' started by vanlith, Jul 18, 2022.
  1. DRTDEVL
    DRTDEVL Road Train Member
    1,705
    3,430
    Jan 27, 2013
    Austin, MN
    Same thing. The DPF has nothing to do with the DEF, DEF is a part of the SCR system. The issue was dosing pump failures, so if there is no DEF available to inject, the EPA would likely put a temporary fix in place where the dealer network could flash each truck for no DEF until a certain date. The manufacturers would have to write the programming, and it would likely cost 1-2 hours of labor per truck for the flash (and the subsequent re-flash to original specs afterward).
    Kairen0001 and AModelCat Thank this.
