Diesel force EGR & DOC/DPF cleaner
Discussion in 'International Forum' started by cprems, Dec 2, 2018.
  1. cprems
    cprems Light Load Member
    97
    40
    Sep 17, 2018
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    I have been using the system at my shop for a little over a year now. Overall, I have great success with it. The easiest way to understand it is to think of it as an alternative way to clean your DOC and DPF without removing/baking/re installing them. You get an added bonus of having anything in you EGR stream (valve/cooler/intake/VGT) cleaned at the same time. Just as always, you must have anything that is not working properly in your aftertreatment system repaired first. I have been fixin' for 20 years and am a very skeptical guy. It has a 80+% success rate with me. It ain't no $250 though! Initial investment is $3500+. I charge $800-$1200 depending on engine. I give it a 4 1/2 star out of 5 star rating.
    devedo Thanks this.
  4. JonJon78
    JonJon78 Road Train Member
    7,241
    43,044
    Jul 1, 2018
    Pittsburgh Power does this I believe they charge around $1500.
  5. balliworld
    balliworld Bobtail Member
    21
    6
    Apr 25, 2019
  6. balliworld
    21
    6
    Apr 25, 2019
  7. balliworld
    21
    6
    Apr 25, 2019
    Where is your shop sir. I wanna get this done. thanks in advance. You can email me at [email protected]
  8. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    I will PM you
  9. Sneakerfix
    Sneakerfix Heavy Load Member
    720
    269
    Apr 22, 2015
    Pasadena,ca
    Ca
    Can you send it to me also
  10. Transportacion R&R
    Transportacion R&R Light Load Member
    175
    73
    Apr 10, 2020
    Where are you located, I need my DD13 cleaned out with it. This includes oil change, filters and all fuel filters correct?
  11. nunofreddy
    nunofreddy Light Load Member
    157
    64
    Jun 3, 2014
    Does doing this properly clean your egr valve or is it better to remove and clean? in thinking of doing this does fuel mileage go back up doing this?
