Different 5th wheel grease for winter?
Discussion in 'Experienced Truckers' Advice' started by PE_T, Nov 24, 2019.
  1. PE_T
    PE_T Road Train Member
    I have been using the red Lucas grease for my 5th wheel, but I’m noticing it stiffens in cold weather. It’s much harder to pump it out of my hand grease pump. I’m thinking perhaps to switch to the green Lucas grease. Any thoughts?
    truckdriver31 Thanks this.
  3. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    Nobody cancelled laws of physics as far as I know yet. All grease will get harder with cold weather. That is why I got power grease gun (18 V Milwaukee).
    OLDSKOOLERnWV, truckdriver31 and PE_T Thank this.
  4. AModelCat
    164,924
    Winter months we switch to an NLGI #1 vs the normal #2 in pretty much everything.
    mhyn, truckdriver31 and PE_T Thank this.
  5. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    I've been using their bottle lube. The oil kind. It works much better and lasts longer then the grease.
    I keep the bottle inside the truck to keep warm.
  6. JReding
    JReding Road Train Member
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    Is that the sticky black stuff? I never had much luck with that.
    As far as putting the stuff on, @PE_Trans , I don’t use a gun, I have a putty knife I keep in a ziplock baggy and a tube. As the tube get lower, I can use the putty knife to cut the tube down, and I can still get the cap back on the tube. Done it this way for years.
  7. D.Tibbitt
    157,286
    Why waste money on grease? Just use the windshield squeege and clean the 5th wheel real good and u wont have any problems
  8. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Should you do that before or after you wash the truck with it. LOL :p
  9. Long FLD
    Long FLD Road Train Member
    12,926
    54,247
    Mar 4, 2015
    Since you pull the same trailer all the time I’d get a Teflon plate for your 5th wheel.
  10. snowwy
    20,612
    13,333
    Jul 6, 2009
    It lasts longer and keeps my kingpin from slopping. Every time I stop at a light.
    My 5th wheel don't have an adjustment.
    I don't have to lube it as much as the grease. Or as often. Or have to use tools to slob grease on.
    Tip bottle upside down and squeeze.
    Grease just mushes out the sides. Makes a mess and what's left dries out in a week.
    Lube bottle don't do that. And will last a couple of weeks. One bottle lasts me 2 months.
  11. IH Truck Guy
    4,988
    57,937
    Mar 2, 2008
    Purgatory
    -20 to -30 I keep a old squeeze bottle filled with drain oil. Squirt a little on before hooking up..
    Works very well,as it mixes with the grease and keeps the grease from getting too stiff.
    dosgatos, bzinger, PE_T and 5 others Thank this.
  12. JReding
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    no matter what I did, I would always get that “string” that wouldn’t break, and would drift in the breeze, usually in my direction. :eek:o_O
