so the company i drive for stuck me in a different truck.. not slipseatin, but the one i was in was old.. this one is the same age, but less mileage.
it has a 4 foot antenna that looks like it came off an old mack.. lol.. and a 2 foot k40, on the other side.. with a little wire/tube.. thingy that ya can raise/lower.i hooked up my cb, as normal. but the swr rating is as faaaar over to the right as possible. on every channel. i tried to mess with the little antennas height, thing but it did nothing..oi found another.. 4 footer in the storage box, hooked it up to where the 2 footer was, and it did the same thing.. do i need new antennas or something else?? ive never had any problems like this in the past. lol
add: i tried to calibrate it..as normal..did nothin, tried my cb in the old truck again, and a buddys truck, and it worked
different truck, new problem
Discussion in 'CB Radio Forum' started by Echo, Mar 5, 2010.
time to get new coax and new antennas
Echo Thanks this. -
It might not be the antenna itself, I'd first check for proper grounding and check the coax for damage.
how would i check that? -
the coax i can probably get to, but the wiring is tucked up in the headliner.. thingy... its an international 9200.. company truck, so i dont think they would like me takin apart their truck.. LOL, the coax is tucked in that area, then it looks like it goes in into a smaller wire that goes down the A pillar, then goes out to the mirror bracket.. etc.. the power supply wires are short, but i guess they work? the cb lights up and all.. i could probably jimmy rig something together if i had to, which i kinda need to do cuz our customers require us to use cb to comunicate with them...etc
I ran temporary coax through the vent window, some run it through t he door jamb. Substitute that with the door closed and if it fixes it then you have found it.
Not knowing what was there to begin with, I would hook up a single antenna on the passenger side with a 50 ohm cable set to use until they move you into it permanently, then you might want to do it like it was. I still prefer the single antenna route; lots easier to tune it.
