Direct freight questions
Discussion in 'Ask An Owner Operator' started by windsmith, Jan 12, 2013.
  1. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    I'd like some input from 1-2 truck O/Os who have secured some direct TL accounts. What's the best way to go about doing this beyond the obvious steps of identifying shippers and asking for freight to haul? Is there a standard contract that you use for new accounts?
  3. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    Never used a contract. Didn't want to be committed to anything. If things didn't work I could just walk away from the business.
    But make sure that you really analyze if any direct freight is worth it. When I look back at one account that we still haul for in almost every case I took a less than market rate back to get the load or had to DH extra miles. All told making it just a good spot market rate vs. the great loaded rate that it is.
    I have found that smaller companies are willing to work with small carriers. Despite what so many that have never made a sales call will say, larger shippers do not have the resources to work with 100's of trucking companies.
  4. windsmith
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Thanks, Bill.
    What I'm specifically looking for is something that I can use to get home and back out again from time to time. Broker rates on freight coming in to where I live aren't worth bumping a dock for, and I have to d/h at least 150 miles to find something worth picking up to take back out. I'm looking for a workable solution to that problem.
    As an example, I ran 400 miles empty to get home on Friday. Not because there wasn't any freight delivering here, but because it was all offered at under $1.25 / mile, and nobody was willing to discuss a better rate. And that held true along the entire route.
  5. G/MAN
    G/MAN Road Train Member
    7,031
    8,625
    Sep 3, 2010
    The main reason to have a contract would be to lock in a rate for the life of the contract. I had one shipper that we never had anything in writing, including any sort of rate confirmation. Everything was done verbally or a handshake. I never had to worry about my money. I was paid as when the loads were delivered.
    windsmith Thanks this.
  6. Marlin46
    Marlin46 Medium Load Member
    504
    299
    Mar 17, 2010
    Atlanta, GA
    With several direct shippers that I have obtained over the years I typically just use the email that goes back and forth with the agreed upon rate as my "rate confirmation" with them. As BBB said it then means there is no contract to potentially not live up to. Most of them are smaller companies with the exception of one. Most are either referrals or a " friend of a friend " made an introduction and it went from there.
  7. BigBadBill
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    Look for loads posted in small towns by small brokers. Then make the cold call on the one or two accounts in that town.
  8. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    I have no contracts with any of my direct shipperes. Its all on a per load basis. Do not want to commit to more than i can handle and most of the shippers i use do not just utilize one o/o or trucking company. I have over 20 direct shippers/recievers i haul for, some very small and some good sized and most of them i found out about by either them posting on load boards or companies i knew about in the areas i run and just called them. Some acually contacted me after i picked up at there yard for other companies. Next time you pick up or del somewhere just ask. Worked for me plenty of times. Contray to what some say alot of big companied will work with single truck o/o's or small compaies because lot of the big trucking outfits do not want to mess with the sorter haul stuff. Two of the shippers i haul for are very large and thats all i do is 300 miles or less loads because the big guys do not want them. But i can not touch the over 500 mile freight becuase that go's to 4 or 5 of the big guys for little money. As far as rates all my direct shipper freight on the inbound is 15% to 25% more and as much as 50% more on the outbound than what brokers are offering.
