Disable “door open” shut down reefer
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RGVTrucker956, Jun 21, 2020.
  1. RGVTrucker956
    RGVTrucker956 Bobtail Member
    27
    4
    Sep 17, 2016
    So I have a Utility 53’ Reefer trailer with roll up door & I was wondering if anyone knows how I can disable the sensor that shuts the unit off when the door is open. That way the unit keeps running when the door is open as well. Any input is highly appreciated. Thank you.
  3. RGVTrucker956
    27
    4
    Sep 17, 2016
    The unit is a Thermo King SB210+
  4. bad-luck
    bad-luck Road Train Member
    3,450
    6,364
    Nov 16, 2013
    Baltimore, Maryland
    The ECM needs to be plugged into and have that changed. I had a low idle switch installed on my old trailer, so I could have it run on low idle when my doors were opened. This was programmed in the ECM, and a toggle switch was installed
    650cat425 and Bean Jr. Thank this.
  5. RGVTrucker956
    27
    4
    Sep 17, 2016
    thank you. I guess I’ll have to take it to Thermo King.
    bad-luck Thanks this.
  6. 062
    062 Road Train Member
    6,347
    34,012
    Oct 20, 2013
    Google it. There is a advanced user screen that will pull up a menu,then turn it off in there. @reeferwrencher may be able to help. It’s been a couple years since I’ve had to do it.
  7. reeferwrencher
    reeferwrencher Medium Load Member
    613
    1,577
    Aug 4, 2018
    Just cut the power wire and tape it off.IT sends power back to the micro to trigger the door open mode.IF you interrupt the circuit it wont come on. Good luck
    062 Thanks this.
