Disabled DEF system
Discussion in 'Trucking Industry Regulations' started by THATSACOMPANYTRUCK, Feb 11, 2018.
  1. THATSACOMPANYTRUCK
    THATSACOMPANYTRUCK Bobtail Member
    4
    Feb 11, 2018
    Recently it came to my attention that the tractor I was driving had an disabled def system.
    My question about this is if the Department of Transportation had discovered this would I as a driver receive some sort of punishment?
    I was told once that if a company disabled the DEF system and was caught doing that there would be major fines sanctioned towards that company but as a company driver what I also be held responsible?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    DOT will do what they do. You can save yourself some typing and just use the three letters.
    I think you are not going to be made to disappear into club fed. But You do not want a truck with anything disabled.
    I hope you are looking for another company to run for by now.
  4. Pedigreed Bulldog
    7,737
    14,425
    May 7, 2011
    It ain't the DOT that will be the problem, but rather the EPA...and it's the owner of the vehicle as well as whoever they suspect might have tampered with the emissions (including any shop that should've noticed and didn't report it).
  5. arrogant steve
    arrogant steve Medium Load Member
    444
    463
    Mar 31, 2016
    East Texas
    Ultimately some of the blame will fall on the driver, you!
  6. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Paranoia much.....there is and has never been any real enforcement of this issue I would guess a full 10 to 30 percent of all of these emmision trucks over 500 k miles are deleted
  7. SoCalRed
    SoCalRed Medium Load Member
    437
    852
    Feb 7, 2017
    CA
    Stay out of California and you’ll be fine. I’ve seen CARB doing emissions inspections at the scales. Don’t think DOT will care about your emissions unless it is something obvious.
  8. 345_Magnum
    345_Magnum Light Load Member
    53
    124
    Feb 11, 2018
    Area 51
    You'll eventually plug up the particulate filter and the engine will de-rate. That's when the fun begins.
    stwik and Justrucking2 Thank this.
  9. racemaxx24
    racemaxx24 Heavy Load Member
    718
    922
    Jul 4, 2014
    East TN
    I would say if the system has been “disabled” they gutted the DPF and retuned it for no emissions. Retains the factory appearance
    Dump 6 axle- 35 Thanks this.
  10. Driver91
    Driver91 Medium Load Member
    479
    287
    Jun 28, 2015
    There is a guy local to me that owns about 15 trucks. All his trucks are 2014 and newer well maintained trucks. He will tell you the first thing he does when he buys a truck is have the def system disabled. Says it cost him 3-5k to do it but in the long run he saves way more than that on maintenance and says the trucks get way better fuel mileage. He has never had a problem with dot. Says he can’t go to CA, but “big deal, I don’t want my trucks in CA anyway”. He says lol.
  11. duckdiver
    duckdiver Road Train Member
    1,062
    877
    Mar 28, 2012
    Surf city
    I am a local ca driver and I hit the scales 4 times everyday or 20 times a week or 80 times a month and in my 5 years of driving I have never seen carb at the scale. My buddy is an owner operator here in ca running local only and his truck is 2011. He has been trucking longer than me and has never gotten caught
    Diesel Dave Thanks this.
