Disconnecting steering axle breaks?
Discussion in 'Questions From New Drivers' started by wanna_be_trucker, Jul 3, 2012.
  1. wanna_be_trucker
    wanna_be_trucker Light Load Member
    50
    14
    Jul 29, 2011
    Athol, Massachusetts
    I've been taking the CDL practice tests on this site, and I repeatedly get an answer that says something about steering axle brakes and disconnecting them. My question is, is there really a way to disconnect steering axle brakes?:biggrin_2554: It just doesn't sound right.
  3. wanna_be_trucker
    50
    14
    Jul 29, 2011
    Thank you for your answers in advanced
    Kevin
  4. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    no, you cannot disconnect them. at one time, there was a valve on the dashboard. (i forget the name, but i think, "brake limiting valve"..??)you would switch that valve from "dry to wet" if the roads were say, well...wet.
    it was thought way back when, that you could lose control as if the truck were to start skidding as the wheels that start to lock up, tend to "take the lead".
    well if you are going forward, those tires are already in the lead.
    it has been, many, many years now since any truck has had that valve on the dashboard. the computer anti-lock brake system helps prevent wheel lock up and skidding.
    so NEVER try to shut off the air supply to the front/steer brakes.
  5. wanna_be_trucker
    50
    14
    Jul 29, 2011
    I knew it didn't sound right!! I just had to find out if there was such a thing.
  6. Admin
    Admin TTR Forum Owner Staff Member Administrator
    10,252
    15,599
    Apr 6, 2009
    Which test were you taking? Please let me know so I can remove the question.
  7. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Back in the day it was also common to totally remove the brake assemblies and drums from the steering axle and never get questioned for it at a scale.
  8. Moe Rhonic
    Moe Rhonic Light Load Member
    212
    52
    May 3, 2012
    Des Plaines, Il
    Why remove it? It's on the actual permit test...
  9. bender
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Sounds like the tests are about 25 years behind the times!
  10. Opus
    132,773
    doubles / trips...... I thought it was some kind of trick question......got it right anyway
    BTW....thank you very much for the tests. It's appreciated.
  11. turnanburn
    turnanburn Medium Load Member
    628
    270
    Jan 25, 2011
    central Vermont
    You might have questions on some other outdated things as well.
    Like "wig-wags," Test takers also confuse the modulating control valve with the brake limiter control, obscure stuff, but it's on the tests.
