Disconnecting things on International LT
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by me myself and I, May 15, 2024.
  1. me myself and I
    me myself and I Heavy Load Member
    736
    312
    Oct 5, 2009
    vernon hills,Il
    Two things. Supply line to fan clutch solenoid. I'm guessing it's a quick connect , but I've never seen one like that.
    And EGR delta pressure sensor plug. It a X15, but different from IXS.
    How do I get them off
  3. Goodysnap
    Goodysnap Road Train Member
    3,778
    9,212
    Jul 12, 2017
    Quick connect fittings can get stuck and frozen. Push in on the collar while pulling out on the nylon line. If it doesn’t come. Just cut the line flush at the fitting and replace the fitting with a new one of your choice either old school or new quick connect. Cut the line with a razor or utility knife to leave a clean straight edge for ease of reassembly.
    On the sensor….
    slide the red locking tab on the connector with a flat screw driver. Squeeze the release tab to remove the connector.New X15 may have a cover over the lock just pop it off with a screwdriver and the same old connector is under the cover.
    runningman0661 Thanks this.
