Do I need a ELD if running interstate under 116 miles
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by VFreightTransport, Feb 7, 2018.
  1. VFreightTransport
    VFreightTransport Bobtail Member
    4
    Massachusetts
    I will be driving into Connecticut everyday from Massachuttsetts in a daycab, do I still need to be ELD Compliant?
    Thanks
  3. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    To answer the specific question...
    Interstate vs. intrastate doesn't matter. Well not unless you have a state exemption/difference (Cali, Texas, ag. etc.)
    If you run paper logs you need to use ELD, unless you use paper logs 8 or less days out of 30.
    If you use the time card exemption, you do not need a paper log.
    To qualify for a time card exemption to logging all three need to be true.
    1. No more than 12 hours on duty/driving per shift.
    2. Start/stop at the same location.
    3. 100 air miles (115 statutory mile) radius from the yard.
    Now if you are right at 115 miles, remember that is a radius from starting. You can drive 600 miles inside that radius. You can go to Radius Around a Point on a Map put in 115 miles, and the starting location to draw a circle. If you breach it, you must log. If you stay inside it all day, you are good with a time card.
