Do relays burn out? How to test...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Michael H, Oct 21, 2016.
  1. Michael H
    Michael H Medium Load Member
    466
    1,023
    Nov 3, 2015
    Arizona
    Howdy keyboard gurus! I replaced the door switch controller for the windows/mirrors and heard a pop. I checked the fuses, all good. Could it be a relay? If so, how do I determine that? I really don't want to put this in the shop at the TA I'm parked at. Neither side works, controller on the passenger side won't roll down the window either. Thanks in advance.
  3. AModelCat
    164,923
    The easy way:
    Simply swap the suspected faulty relay with another relay of the same rating. If the accessory you swapped the possible bad relay to still works, and the circuit you have issues with still doesn't. Relay is not at fault.
    thejackal and Ezrider_48501 Thank this.
  4. Michael H
    466
    1,023
    Nov 3, 2015
    Arizona
  5. melsno
    melsno Light Load Member
    210
    109
    Dec 11, 2015
    Have you checked the fuses behide the glove box? Just about every fuse that is related to your cab is in there. I think also a few relays. Check the fuses first then switch some relays around that are the same to see if that helps. Best way i found out is switch relays around but the stickers will tell you which is which.
  6. thejackal
    thejackal Road Train Member
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    Chances are, if u heard a pop, it's a timed circuit breaker...after a time it should reset itself. Or pop again.
  7. Michael H
    466
    1,023
    Nov 3, 2015
    Arizona
    Changed the relays, all fuses have continuity, and the panel is new. I think I've exhausted the obvious stuff. Funny, the door lock switch works, but I still can't roll down the windows. Might be time to turn it over to the pros.
  8. Michael H
    466
    1,023
    Nov 3, 2015
    Arizona
    Just a quick follow-up to close the thread. I ended up having to replace a wiring harness. Easiest thing to do and saved a lot of labor. Problem solved. Thanks everyone.
    SAR Thanks this.
