Does Caterpiller make 2 different 9 pin connectors?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TowHaul, Feb 21, 2023.
  1. TowHaul
    TowHaul Medium Load Member
    416
    79
    Mar 7, 2016
    The picture on the left is the correct pine setup that works with my truck, but the wider 3 pin setup on the right is for the scan tool i purchased. I am not sure what to do or what to even search for to get the correct connector....
  3. TowHaul
    416
    79
    Mar 7, 2016
    I found this but hope i dont have to buy another cable...[​IMG]
  4. Animosus
    Animosus Heavy Load Member
    733
    2,916
    Dec 7, 2015
    SE Wyoming
    2016 and newer use the green 500kbs 9-pin which is backwards but not forward compatible with the 250kbs black/gray 9 pin. Caterpillar also has their own proprietary 9 pin they use on their equipment.
    BoxCarKidd and D.Tibbitt Thank this.
  5. TowHaul
    416
    79
    Mar 7, 2016
    so do i just get a dremel and file down those 3 pin walls? Also my truck is a 2002 Caterpillar engine
  6. TowHaul
    416
    79
    Mar 7, 2016
    apparently there is a "J1939" port (I have) and i am not sure what the name of the other type of port is?
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    I cannot answer that but would be afraid to do that. The on road Cats have a standard connector. My scan tool has a different connector for off road Cats. Call your scan tool supplier.
    Bean Jr. Thanks this.
  8. TowHaul
    416
    79
    Mar 7, 2016
  9. TowHaul
    416
    79
    Mar 7, 2016
    my on road CAT has the J1939 connection. The cat diagnostic tool however has a standard connection...
  10. TowHaul
    416
    79
    Mar 7, 2016
    I don't speak Chinese :rolleyes:
    BoxCarKidd and Hammer166 Thank this.
  11. bjytech
    bjytech Light Load Member
    246
    222
    Nov 9, 2013
    The one on the right is the offroad connector( proprietary cat data link), pin assignments are different than the truck j1939 standard(that's why they made it so you can't plug it into the wrong one) so it will not work with your truck.
    TowHaul Thanks this.
