Does DOT allow for fuel weight
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, Jan 27, 2017.
  1. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    193
    60
    Apr 13, 2016
    If I'm under gross and axle weight and then after I fuel up I go over gross and axle weight will they stop me when I go through a scale.
    How much does DOT allow for fuel weight? If they do so at all?
    RollingRecaps Thanks this.
  3. Pnwtrucker
    Pnwtrucker Medium Load Member
    383
    821
    Nov 5, 2016
    How much are you over? Will be hard to convince them it's simply fuel. 500 pounds over I wouldn't worry. Do you have APU? There's allowance for that 500 pounds I believe. Plus you'll burn some fuel off before the scale.
    Jdm5jdm5 Thanks this.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,575
    9,937
    Mar 30, 2014
    The total gross allowed without permits is 80,000 lbs. Many states allow 400 lbs extra if you have an APU. If you weigh 80,500, without an APU, you probably will get a ticket. Most scales will not let an over gross slide, and you are probably over on axle too.
  5. Jdm5jdm5
    193
    60
    Apr 13, 2016
    I just fueled up and I'm 380 over on steer and 220 over on gross
  6. Jdm5jdm5
    193
    60
    Apr 13, 2016
    No I don't have an APU
  7. Pnwtrucker
    383
    821
    Nov 5, 2016
    Personally I wouldn't worry just roll. 12,380 on steer and 80,220 I'd roll.
    WildTiger1990, skellr, Thull and 7 others Thank this.
  8. Jdm5jdm5
    193
    60
    Apr 13, 2016
    And, I don't have an APU
  9. Pnwtrucker
    383
    821
    Nov 5, 2016
    How far to the first scale?
    RedRover and Jdm5jdm5 Thank this.
  10. Bean Jr.
    5,575
    9,937
    Mar 30, 2014
    Many people think you are only allowed 12,000 on the steer axle. In fact you are allowed the lowest of these 3 things; 20,000 lbs, single axle, or the maximum rating for the front axle (often between 12,500 and 13,500) and the tire rating, usually 6,700 lbs. I have never had a DOT officer check the stickers on the door jamb to see what the axle rating is, so they usually consider 12,500 legal, which means you need to burn off only 220 lbs of fuel. 8 lbs a gallon is about 28 gallons and at 7 mpg about 200 miles. our probably will not get hassled for less than 50 lbs over gross.
  11. Pnwtrucker
    383
    821
    Nov 5, 2016
    Bottom line id run it
    not4hire, Jdm5jdm5 and Bean Jr. Thank this.
