Does DOT allow for fuel weight
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, Jan 27, 2017.
  1. gokiddogo
    gokiddogo Road Train Member
    Mar 5, 2012
    8,786
    Thanks Received:
    14,769
    Ontario Canada
    Yes. Do that until you get infected with a sick obsession to cross the scales as close as possible to 12,34,34. They see that they know you are doing your job and most likely have the rest of your stuff in order.
    Here's a question for the experts. What happens if you come through a scale say at 79500 but are unable to redistribute the weight to be axle legal? I understand it should never happen, the truck should of been loaded properly in the first place. But what happens when it does happen...?
    Lepton1 Thanks this.
  2. Lepton1
    Lepton1 Road Train Member
    Nov 23, 2012
    12,647
    Thanks Received:
    25,589
    Yukon, OK
    Buy an overweight permit or redistribute the load. I saw that happen to a grain hauler. He rolled up his sleeves in the hot sun with a snow shovel and started moving a couple of tons of corn. Not sure if they issued a ticket.
    If need be you have to hire a forklift to change weight distribution if you can't or don't want to get overweight permits.
  3. pattyj
    pattyj Road Train Member
    Jul 19, 2008
    22,474
    Thanks Received:
    20,137
    Sioux City,ia
    If possible take it back to get reworked,maybe call your company or hope you don't get caught and learn from that exp.Also never thrust an onsite scale always take it to a cat scale.
  4. gokiddogo
    Mar 5, 2012
    8,786
    Thanks Received:
    14,769
    Ontario Canada
    The main reason I ask is I can't get much on the steers... 79500 is about my maximum gross while having 34/34 .. I now understand there is more to the stretched out hoods than looking cool or a nicer ride .. and why they often pull spread axles. Maybe I'll get me a spread axle reefer...
    wore out and Lepton1 Thank this.
  5. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    Apr 13, 2016
    193
    Thanks Received:
    60
    Which states would you say are the most strict
  6. gokiddogo
    Mar 5, 2012
    8,786
    Thanks Received:
    14,769
    Ontario Canada
    Virginia and Nebraska are my nemesis ...lol....
    Oregon Washington Idaho have let me slide one time with 35000 on drives... although I think maybe he wasn't looking..
  7. thelushlarry
    thelushlarry Road Train Member
    Jan 9, 2012
    3,023
    Thanks Received:
    9,002
    glasgow ky
    You can just explain it to the DOT officer they are very understanding people!
    bottomdumpin and Lepton1 Thank this.
  8. reverendhandy
    reverendhandy Medium Load Member
    Jan 24, 2017
    309
    Thanks Received:
    401
    Modesto, CA
  9. cdgoza
    cdgoza Light Load Member
    Jan 24, 2015
    212
    Thanks Received:
    128
    I got away with a warning 1500 over on drives once. Then again it's not just sliding axles for me to adjust weight.
    Jdm5jdm5 Thanks this.
  10. Lepton1
    Nov 23, 2012
    12,647
    Thanks Received:
    25,589
    Yukon, OK
    This isn't always possible. The scale may put you OOS until your weights are legal or until you buy an overweight permit.
    Other than the time I saw the grain hauler reworking his load with a shovel, I have also seen a dry van getting a load redone with a forklift and a pallet jack.
    Fun times.
    pattyj Thanks this.
