Does this scale ticket look right? Scale not functioning properly?
Discussion in 'Flatbed Trucking Forum' started by TravR1, Dec 28, 2021.
  1. TravR1
    TravR1 Road Train Member
    3,695
    9,759
    Nov 9, 2017
    TX
    So I've been at this at a Loves for about an hour.
    Is there some trick to getting an accurate weight? The employees don't seem to know any better than me.
    I pulled on like I saw on the video and they said that's wrong.
    Or is there some truck to that? I don't think I have 101k on my axles.
    The load should be about 47k total of rock.
    austinmike and BennysPennys Thank this.
  3. Arctic_fox
    4,486
    25,264
    Sep 16, 2016
    Umm.......methinks you should call cat because that particular kitty scale is roadkill.
    MOBee, OLDSKOOLERnWV, MACK E-6 and 5 others Thank this.
  4. JStokley
    JStokley Bobtail Member
    28
    42
    Dec 13, 2021
    Something is messed up with the scale. Your allowed 12 on steer 34 on each set of tandems. If you add 34+34+12=80k. You only have 23+23+10=56k
  5. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,721
    Nov 7, 2021
    B.C. Canada
    You are under 58,000 lbs according to that.
    Hit the road and go like Fumanchu.
  6. D.Tibbitt
    156,412
    Are you trying to split weigh with a spread axle? Or just regular weigh?
    JoeyJunk, Lostkeys, Oxbow and 3 others Thank this.
  7. TravR1
    3,695
    9,759
    Nov 9, 2017
    TX
    They said I should stop on the scales as normal then pull forward for a second weigh with axles on the 3rd and 4th pad.
    That weigh ticket was the result.
    Vampire, Lostkeys, Pamela1990 and 2 others Thank this.
  8. JStokley
    28
    42
    Dec 13, 2021
    Me thinks it added the weight on the right column as well. 44k +57k is 101k
    BennysPennys and TravR1 Thank this.
  9. TravR1
    3,695
    9,759
    Nov 9, 2017
    TX
    That ticket tells me my axle total weight is 100k. Lol
    BennysPennys and D.Tibbitt Thank this.
  10. TravR1
    3,695
    9,759
    Nov 9, 2017
    TX
    I was
    Is the normal weigh easier?
  11. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Might want to learn actually regulations before giving wrong information.
    Plus, you are assuming it's a tandem setup....
