Does this sound about right?
Discussion in 'CB Radio Forum' started by JackinTruck, Dec 30, 2016.
  1. JackinTruck
    JackinTruck Bobtail Member
    Dec 30, 2016
    Okay so I called a local CB shop in Ontario California you know nothing about electronic stores installation so I told the gentleman I need a CB installed would like to buy used Cb and I need everything else and all that stuff. I have a 2010 freightliner it's got the coaxial coming out of the dash. Anyways he quoted me $100 for a used Cobra CB refurbished ,anywhere from $25 to 40 for a decent CB antenna ,then he quoted me $250 for the installation of the antenna coaxial anyways after I added up all the numbers it came to about $400. Does that sound about right? I appreciate any information you guys could give me
  3. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    If you're not in a hurry, browse craigslist for used radios. I've bought a few Cobra 29s for $30 or less and they were near mint condition.
  4. Diesel Dave
    9,687
    32,971
    Jan 20, 2010
    Hesperia, Ca.
    Was that shop called CB Radio Shop ? Was it down the street from the TA on Guasti Rd?
  5. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Just shootin' from the hip but the install price sounds darn high to me
  6. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Sounds about right price wise.
    If I was in the business I wouldn't touch a truck for less than 65 bucks an hour. Some of these installs can be kind of nightmarish and end up taking all day trying to chase down ground problems.
  7. Ridgeline
    22,727
    123,498
    No it doesn't unless there is a guarantee it will work right and if it does not, they won't charge you to fix it.
    The coax install should be at $150 at most. A good tech will do it in less than an hour and a half, lousy ones will take three hours.
    bored silly Thanks this.
  8. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    And how many hours did it take you on your friends Freightliner Cascadia?
  9. Ridgeline
    22,727
    123,498
    Running the coax was about 35 minutes. It took maybe another 20 minute to pull the panels off.
  10. JackinTruck
    Dec 30, 2016
    The cb shop I was referred to is next door to a truck wash. It's on Valley Boulevard just east of cherry I think the owner's name is Ron
    Diesel Dave Thanks this.
  11. flyby1971
    flyby1971 Light Load Member
    297
    256
    Dec 26, 2016
    CDA ID
    Kinda depends upon how clean of an install you want. Wires and coax out floppin in the breeze for the world to see? Or tucked away and ran inside your mirror mounts? The radio will be checked out and maybe pumped a bit. Nothing special. They will / should be matching your SWRs for the set up. That stuff takes time and won't be a wham bam job. Betcha it should take a couple hours to complete IF done properly.
