Does WeBoost work like they claim it does?
Discussion in 'Ask An Owner Operator' started by RussianBearTruckeR, Jan 19, 2019.
  1. RussianBearTruckeR
    RussianBearTruckeR Heavy Load Member
    730
    788
    Jul 9, 2018
    Jacksonville, FL
    Does WeBoost work like it states?
    Best option for steadier internet, calls (reduces dropped calls, reception, clarity of call)?
    Anyone using something else for calls/internet stability?
  3. Ridgeline
    22,768
    124,375
    Never had luck with it, try a wilson cell expander system, they work well.
    RussianBearTruckeR Thanks this.
  4. RussianBearTruckeR
    730
    788
    Jul 9, 2018
    Jacksonville, FL
    Thanks for the suggestion:
    Wilson makes WeBoost Cell Phone Signal Boosters ? unless I located the wrong company/product...
  5. Ridgeline
    22,768
    124,375
    I see that now, Yep you are right. The one I got was the small little thing and it didn't do much at all in the car.
    I got their "Drive" system for my pickup and their building system for the house because of the distance from the cell towers. These work and have used wilson for the past 15 years.
  6. The Crossword Trucker
    The Crossword Trucker Road Train Member
    1,172
    2,333
    Feb 21, 2015
    I notice there are a bunch of knockoffs on amazon
    Has anyone here tried one?
  7. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    https://www.amazon.com/gp/product/B0871SZQDW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    I use this at my house and it works pretty well. I used to have to stand by the windows to get service, and it would be 1-2 bars at best. Now I get 3-4 bars when I'm in the room with the booster. In order for it to work best, you'll want an app to figure out which direction the tower with the best signal is. The U-bolts that come with the kit fit perfectly on a load lock, which is what I'm using between the roof overhang and the ground as my antenna pole. The other thing you'll want to figure out is how to run the signal wire into the truck.
    It will not get you service where none exists, it will only boost weak signals. I don't think it will be much use driving if the antenna is directional, but I haven't tested it over the road.
  8. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Used it (Wilson with a cradle to set the phone in) lots in remote areas. It worked as advertised: if there is even a hint of a signal, it will boost it; if there is no signal, you're SOL.
    There were a couple of models up-line from the one I bought; one had a plug-in for the phone, the other had an internal antenna so you could "roam" around the inside of the truck (lol) and didn't have to have the phone in the cradle.
