Doing a rack job on dd13 engine.
Discussion in 'Freightliner Forum' started by All out Trucking, Jan 25, 2022.
  1. All out Trucking
    All out Trucking Bobtail Member
    I have 2013 cascadia dd13 with 714,000 miles. What does that mean, the effect on the engine, consist of and how often should this be done.
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    It means adjusting the valve lash to manufacturer specs. If you don't know when it was last done, do it. Should be good till 1 million.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,930
    Mar 30, 2014
    Running the rack is a misnomer. 2 cycle Jimmies controlled the throttle with a rack gear, ala rack and pinion steering. As setting that was part of doing the overhead on them, they calledit "Running the rack" to differentiate from tuning a Cummins.
    Hammer166, Dino soar, msh and 2 others Thank this.
  5. AModelCat
    164,925
    As mentioned above, no rack on anything on-road built in the last 20-25 years.
    Bean Jr., msh and QUALITYTRUCK Thank this.
  6. msh
    msh Light Load Member
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    DD says first valve lash adjustment must be done after 100k, then after 500k miles. I do adjustments every 250k miles...
  7. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I see you guys talking about rack jobs and DD I thought you were talking about something like this:
    QUALITYTRUCK, Hammer166 and Bean Jr. Thank this.
  8. MAMservices
    MAMservices Medium Load Member
    597
    4,387
    Aug 9, 2021
    Bean Jr. Thanks this.
