Doing The Dew Doesn’t Work With Tennessee DOT
Discussion in 'Other News' started by mjd4277, Aug 12, 2024.
  1. mjd4277
    mjd4277 Road Train Member
    14,746
    45,441
    Oct 4, 2015
    Fitchburg,MA
  3. MACK E-6
    50,089
    238,984
  4. mjd4277
    14,746
    45,441
    Oct 4, 2015
    Fitchburg,MA
    Blew an axle seal.
    It’s happened to me a couple of times.
    On my previous truck the OEM axle seals had the consistency of paper, they fell apart as such.
  5. Flat Earth Trucker
    4,322
    16,670
    Nov 19, 2018
    Had some tractor haulers deliver new Peterbilt 579's to the yard in Visalia several years ago. For whatever reason the hub seal was removed during during transit and a square of wood was screwed in as a cover.
    The replacement seal the transporters used didn't fit right, so it was a stop at the ole Petro to have the correct size seal installed.
  6. wore out
    wore out Numbered Classic
    17,383
    216,010
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    No what he actually done is blowed a differential. Pulled the axles out of it and locked the power divider in to get it to pull. Lots of times leaving the axles in and just locking the power divider in causes carnage that results in impossible movement. It’s and old owner op trick used for years. Tennessee is a bunch of ####in morons. Never mind the people in this thread ain’t ever been there and won’t ever get it.
    Hub seals are inside axles seal to hub with a gasket or silicone. It’s only splash oil and not really a big deal. The wood takes the place of the axle and keeps oil from splashing out. If axles are removed the the hub floats on spindle like a trailer axle and you don’t have to remove the drive shaft to tow it.
  7. Cattleman84
    Cattleman84 Road Train Member
    10,031
    71,677
    Nov 1, 2017
    The Sticks, Idaho
    Had a couple of wanna be mechanics at a place i used to work destroy a diff because they forgot to refill it after having it split in half to reseal it. When it went boom I got called to do a road side rescue on a busy on ramp to I-15. I took a battery impact, sockets, and a big hammer.... Removed both the axles from that diff, locked the power divider, and told the driver to head STRAIGHT to the shop 5 miles away. Took me less than 15 mins roadside.
    So yeah, been there done that.
  8. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    There’s more to this story. This is a super single and there’s bodywork around it. I’ve no idea what this is mounted to.
    Flat Earth Trucker and Long FLD Thank this.
  9. bryan21384
    bryan21384 Road Train Member
    15,762
    34,354
    Sep 18, 2009
    Memphis, TN
    He's doing it wrong. If he had used flex seal, he would have gotten away with it till he got to a shop. Don't ask me how I know that.
  10. sevenmph
    sevenmph Road Train Member
    2,961
    14,883
    Jan 26, 2007
    Pinellas county Florida
    He was also driving while suspended. Wonder how a rocket scientist like that got suspended?
