dont hear much on channels but static
Discussion in 'CB Radio Forum' started by gecryan, Nov 30, 2011.
  1. gecryan
    gecryan Bobtail Member
    10
    hello all, im a noob to the site (first post) and a noob when it comes to cb radio's...
    I have a cobra 29nw st wx (stock mic) that i bought new years ago and have just now mounted it up and a radioshack 26" (maybe cant remember) antenna magnet mount on top (roof) dead center of my 2000 ford explorer sport...
    not letting me post pics :biggrin_25510:
    I have tried everything i can think/find online but my issue is i dont really hear anyone talking on channel 19 (pretty sure thats the "big" one) all i seem to get is static.....
    i did a "radio check" today and i got a "its work'n" response when i was on I-81 exit 29-24....
    i can take more pics if needed as the two i hope work are rather outdated:
    my radio is connected to a (so its on with the key) relay then to a fuse then battery, i have opened up my case and used two "board screws" and the round circle crimp ends (that you can use a bolt or screw to mount tight) and have grounded my radio to my dash frame with two 16 awg strands of wire that terminate togeather to the frame with a single round crimp end with a quick disconnect in between.....
    i have my antenna ran under my center console, below my glovebox, up my passangerside a-pillar, and out the rear pass window (my explorer is a 2 door) then through the opening of my crossbar, back halfway it is ziptied to a round plastic hook, straight over to the antenna(mag mount) i then have an 8 awg wire grounding my antenna to my roof (cable less than 3ft)
    my swr (ik bad to do but no extra $$$) using the built in meter says i have like under 1.1-1.18 swr on 1-40 (best its ever been after i grounded the antenna)
    but i still dont hear people talking on 98% of the channels i get some on channel 6 and sometimes 11 but not much else
    as usual (normal) the weather comes in great
    does anyone have any suggestions?
  3. gecryan
    10
    going to post pics
  4. gecryan
    10
  5. gecryan
    10
  6. gecryan
    10
  7. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    First thing, welcome.
    Now....let me say it now....a 26 inch tall antenna for CB is not going to get you heard much or let you hear. If this is a magnet mount (presuming it is) you want at least, 5 ft of whip in the air. A Wilson 1000 would do you good.
    You did get it right by putting the antenna dead middle of roof. That's the best spot for it.
    If you want to hear people on 19, drive next to an interstate and listen. Or go to a truck stop and listen. Other than when skip kicks in, you probably won't hear much on the CB. Not as many people use the CB anymore. Channel 19 though is the official highway channel and also considered by some to be the official truckers channel.
    The people you hear on channel 6 are the "super bowl" and it's mostly african american operators who run 10's of thousands of watts of power. 11 is another channel they use. You probably won't get a radio check from any of them unless they quit keying up long enough to hear you.
    The SWR meter in the radio is not accurate so take the readings with a grain of salt. An external SWR meter is what you want/need. Radioshack used to sell one for $40 that is decent.
    rabbiporkchop and gecryan Thank this.
  8. gecryan
    10
  9. gecryan
    10
  10. gecryan
    10
    :biggrin_25514:
    :biggrin_25514:
    once i get one of these do you think all will be well with my setup?:biggrin_2554:
    should i run anything different or any improvements you recommend?
  11. Turbo-T
    1,953
    708
    May 31, 2009
    Yes you will have increased transmit and receive. It won't always mean you will get more people to talk to you, but you will out talk the guy with the smaller antenna.
    Your antenna size is what makes or breaks the radio. The best antenna for a mobile is a 102 whip, but most people agree that a 9 ft whip is not practical, even though the whip is flexible and will take a beating, regardless how many tree limbs and bank canopies you might hit.
    So a 5 ft whip like I posted is about the next best thing. it won't do as well as a 102 whip but it will be better than what you have now, for sure.
    Coax is the next thing to look into. You don't want any coax that will allow the signal to be lost. I prefer RG8X. Also keep the coax as short as needed to connect the radio to the antenna. Despite what anyone says you don't need 18 feet of coax if 9 will do the trick.
    As for the radio, you can have it checked to ensure it's tuned on frequency if you want, but don't fall for the "peak" thing where a CB shop says they can get your Cobra 29 to do 35 watts. All too often CB shops wreck radios trying to get more power out of them. All they end up doing is causing the radio to distort to make the "feel good" meter to swing far to the right. The last thing you want is a radio that sound like crap on the air.
    Hellrost, rabbiporkchop and gecryan Thank this.
