Door problems
Discussion in 'Questions From New Drivers' started by Dumb, Apr 28, 2019.
  1. InTooDeep
    4,981
    37,364
    Jan 17, 2016
    Carmichael CA
    Maybe he just might drop back by and let us know
    lovesthedrive Thanks this.
  3. WesternPlains
    6,369
    57,424
    Sep 1, 2017
    Rapid City, SD
    I had a problem with latch on drivers door.
    Used a two inch wide tie down strap. Went to other door handle. Worked great.
    Lepton1 Thanks this.
  4. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    Handy thing to have for the zombie apocalypse.
    WesternPlains and Hammer166 Thank this.
  5. D.Tibbitt
    157,289
    Put a bungie on it then go grab a container chassis so u can fit right in with the rest the can haulers lol
  6. tscottme
    tscottme Road Train Member
    On wabash trailers the hinges are made to break in the middle to protect the door and the trailer.
    x1Heavy Thanks this.
  7. Lepton1
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    I'm going to assume you mean your driver's door. If this is the case it would help if you let us know the make, model, and year. Upload some pictures as well.
  8. Ridgeline
    22,747
    123,821
    You have what is called a sprung door, I had a few trucks that this happened to and you really need to take it to a good body shop to get it fixed otherwise it will never be the same and never close right.
  9. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I picked up a loaded KW 100 one morning about 3 am. When I got there the door was open and the New Mexico wind had sprung it enough it would not laugh. I went and just left the window down, and could hold it shut pretty well by resting mo arm on it. It was just a short 250 mile round trip with feed for a feed store.
    About 90 miles in I blew the right front steer tire, iirc it was a 74 and no power steering, we were in the ditch right now, and with both hands holding the wheel as best I could, the door was just flopping open all the way and slamming shut about as fast as possible it seemed like. lol
    The guy that owned the feed store, was not happy about me being late to start with, but them proceeded to chew me out because the load had all rocked forward, enough that it all had to be restacked before his little dolly could rock the sacks back. I informed him pretty quick, I had heard enough and I was pretty sure he was ina better mood than I was in.
  10. InTooDeep
    4,981
    37,364
    Jan 17, 2016
    Carmichael CA
    In cars we used to use 1" pipe nipples in the hinges and pull door against them till it would adjust enough to close
