DOT Blitz- Brake shoe wear indicator???
Discussion in 'Ask An Owner Operator' started by istumped, May 3, 2025.
  1. istumped
    istumped Medium Load Member
    504
    241
    Feb 8, 2015
    I have been in this industry a very,very long time(25 yrs). I still can't get a straight answer. The question is when are brake shoes on a drum/shoe setup out of service? Is it when the outside edge wears to the 1/4 inch wear mark? Or is it out old service when the center of the brake shoe hits the 1/4 inch wear mark? Which is it? Everyone gives me a different answer even LEO officers!!!!
    Rideandrepair Thanks this.
  3. Big Road Skateboard
    7,203
    40,936
    May 2, 2021
    I would say it's very subjective. One would OOS, while another says good.
    I try to keep brakes and tires in a condition that there's no questioning they're good.
  4. abyliks
    abyliks Road Train Member
    4,150
    9,789
    May 2, 2010
    ludlow MA
    Depends on how bad a day the revenue pig is having
  5. MacLean
    MacLean Road Train Member
    1,382
    4,097
    Sep 12, 2017
    It’s goofy for sure. I even got a level 3 once and everything was good but the the disc brakes had dust Shields and because he couldn’t see around them he wouldn’t give me my sticker.
  6. W923
    W923 Road Train Member
    1,426
    4,421
    Feb 28, 2022
    I’d assume when any point is less than 1/4 thick you are opening yourself up for trouble….unfortunately your at their mercy
    If you’re worried about the edge being worn down but can’t afford new parts take the drums off and flip the shoes around…while you’re at it take a hand grinder and knock off that ridge at the edge of the drum….. maybe cut the wear indicator down a little deeper to…
    I used to work for a guy that always wanted me to do this….not generally my favorite idea but it would get him another couple months out of a set of brakes.
    If you can put shields on them it helps keep the road grit from chewing up the edges of the drum and shoe. I know I didn’t answer your question but unfortunately the cheapest option is just don’t let them have the chance to decide how to interpret the 1/4 inch deal
  7. 062
    062 Road Train Member
    6,347
    34,012
    Oct 20, 2013
    Oxbow and Rideandrepair Thank this.
  8. El Hueso
    El Hueso Medium Load Member
    470
    1,320
    Dec 29, 2024
    El Paso. Tejas
    As you approach 5/16" it's time. That's basically it. By the time you do another month or two it's going to be less than 1/4" and you're asking for trouble. The code is "Less than 1/4" but you know better than to roll in there with exactly 1/4" left on a shoe. Could you get by? Probably. But that's your decision. If you hit something and DOT goes under there and looks at the brakes, that's on you and your company. The way DOT sees it, If you are at 1/4" you have brakes but, a whole lot of people would be trying to stop their trucks with rivets on the drums if they said "Get this fixed before we see you next time"
  9. KDHCryo
    KDHCryo Medium Load Member
    649
    997
    Sep 14, 2023
    I run discs, they don't even look. Because they cant
    You old timers need to get a better braking system
  10. abyliks
    4,150
    9,789
    May 2, 2010
    ludlow MA
    I actually just picked up my first trailer with discs on Thursday,
    Oxbow, Rideandrepair and Siinman Thank this.
  11. 86scotty
    86scotty Road Train Member
    4,728
    12,991
    Aug 27, 2017
    Appalachia
    Thoughts so far?
    Oxbow Thanks this.
