Dot def deletion inspection
Discussion in 'Ask An Owner Operator' started by wheres da $$$, Oct 3, 2021.
  1. wheres da $$$
    wheres da $$$ Bobtail Member
    41
    Does anyone know about this def deletion check DOT is doing? I've heard in NJ there putting a sensor at the end of the pipe and getting you to rev up to see the at quality or something...so much of us have deleted def whats the fine how strict are they doing this if this is going to be a trend how easy will it be to reverse the deletion....thanks drivers
  3. Siinman
    Siinman Road Train Member
    5,515
    14,177
    Mar 5, 2017
    Kansas City, MO.
    This very well may cost you more than the DEF problems them selves would had cost. Good luck as they will most likely put you out of commission on the spot.
    How long will it take you to put everything back together?
    How much will it cost to add it back on?
    What will be the fine?
    Sounds like a lot of money and not worth it.
    86scotty, homeskillet and feldsforever Thank this.
  4. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Is there some reason you have to run Jersey? I avoid that place like the plague.
  5. AModelCat
    164,670
    The probe down the pipe is an opacity test. It checks for smoke. Nothing to do with DEF.
  6. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    I thought Cali and new York where the worry states. But then again, I think mo checks the color of your diesel.
    bzinger Thanks this.
  7. Mototom
    Mototom Road Train Member
    1,388
    2,703
    May 7, 2019
    Mo will dip your tanks, even on pickups.
    Reason being is so many farm kids don't wanna pay for fuel so they borrow some of grand daddys farm fuel after all no one will ever know right??
    bzinger, w9l, jason6541 and 3 others Thank this.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    Iowa does it too they like to pull in to livestock sale barns and grain elevators and check big trucks and pickups
  9. Ruthless
    Ruthless Road Train Member
    9,183
    91,163
    Aug 28, 2010
    The City.
    Correct
    NJ CT NY all run this test in both scale house and roadside events- not super often but they do all do them. I can’t speak to other states from personal experience.
    Long as the exhaust meets given parameters the truck passes. they generally give a window sticker for a passing test as well.
    If a vehicle does not pass the opacity test; the operator is generally given a “fix it ticket”
    There may be a threshold whereupon the vehicle is put OOS but I have never heard of it happening.
  10. wis bang
    wis bang Road Train Member
    3,454
    4,098
    Jan 12, 2011
    Levittown, PA
    NJ's emissions 'opacity' [smoke] has been around for years. NJ registered trucks need to re-test within 90 days of renewing or face a $700.00 fine.
    Took about 2 years to clean up the Macks [mostly] that ran better and smoked when the emissions valve malfufnctioned. That fine was $1700 reduced in court to the normal amount IF you presented proof of repair at court. My owner operators do it with the anual FMCSA inspection every year.
    That left the specially set up roving compliance units [cost $$$] now set up and test anybody looking for smoky exhaust.
    Nothing to do with DEF and current FMCSA/EPA emissions. In the past 10 year I've had 2 of my NJ based units tested on the road. Your mileage may vary BUT the odds are with you simply because of the huge number ot trucks on the highway here.
    bzinger, Cat sdp and 77fib77 Thank this.
  11. Big Road Skateboard
    7,098
    40,284
    May 2, 2021
    Exactly. They can't tell it's deleted, but they can tell it's not within spec.
    feldsforever and Bean Jr. Thank this.
