Dot physical and drug test at the same time.
Discussion in 'Questions From New Drivers' started by Baz, Apr 11, 2022.
  1. Baz
    Baz Bobtail Member
    29
    5
    Mar 10, 2022
    I never had to do both at the same time. Do i have to do a urine test for the drug test and another for the physical? Or could they just use one for both? Thanks
    motocross25 Thanks this.
  3. motocross25
    motocross25 Road Train Member
    3,893
    11,966
    Sep 23, 2010
    Overland Park, KS
    They used the same for both last time I did a new hire drug test and physical.
    Bean Jr. Thanks this.
  4. Baz
    Baz Bobtail Member
    29
    5
    Mar 10, 2022
    I hope so, because i can barely go once. Thanks
  5. motocross25
    3,893
    11,966
    Sep 23, 2010
    Overland Park, KS
    I did have one a few years back and the nurse dipped the stick in there and flushed the cup contents and all that and then realized I needed a drug test too. So out in the waiting room I went chugging water. I’d give your nurse a friendly reminder you’re there for both when you’re back there with her so they don’t dump it too quick.
  6. Moosetek13
    Moosetek13 Road Train Member
    14,994
    19,062
    Nov 1, 2010
    Burnsville, MN
    Chugging water so you can pee again can lead to inconsistent results.
    One result is that they see it as an attempt to dilute the sample.
  7. rockeee
    rockeee Medium Load Member
    338
    654
    Apr 22, 2015
    Kalama, Wa
    Under those circumstances I doubt that would be an issue at all.
  8. Lexuslane
    Lexuslane Medium Load Member
    496
    1,009
    Oct 22, 2021
    It also raises your blood pressure . If you have issues with your BP , chugging water will make it even higher .
    Moosetek13 Thanks this.
  9. rockeee
    338
    654
    Apr 22, 2015
    Kalama, Wa
    It still would not matter if doing a drug test, unless you have a heart attack lol
  10. Lexuslane
    496
    1,009
    Oct 22, 2021
    I thought a lot of guys had trouble getting a card because of their BP was too high
    tscottme Thanks this.
  11. rockeee
    338
    654
    Apr 22, 2015
    Kalama, Wa
    Yes like me. I was just saying if you go in for a drug test, they will not be checking your BP, at least that has never been my experience. Or like someone mentioned, if you go in for both and do your physical and they toss your urine sample I don't think drinking a ton of water is going to be an issue. Now if you do the drug test first and they toss it, I suppose it could be a problem
