DOT Physical question
Discussion in 'Questions From New Drivers' started by Bigdan9596, Feb 13, 2019.
  1. Bigdan9596
    Bigdan9596 Bobtail Member
    I had a DOT Exam in dec 2018 it expires dec 2019. I brought a copy of exam into DMV and received a letter that they have it on file. In January, I joined a company who did an in house dot exam but I got a certificate from the doctor like my other one. They said it replaces my december 2018 one the question I have is my December exam card still valid being the January one was an in house exam? Any info is much appreciated thanks In advance
  3. Espressolane
    18,732
    117,461
    A DOT med card from a DOT registered examiner is good for up to two years. If the company sent you for an exam to get a new card, You should submit the new one to your DMV.
    BUMBACLADWAR and deathB4decaf Thank this.
  4. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Your latest exam supersedes your previous one. Also, you're only allowed one card in the truck. If DOT finds you have two in the truck, you might be liable for a fine.
    BUMBACLADWAR Thanks this.
  5. Moose1958
    Moose1958 Road Train Member
    15,298
    33,966
    Dec 17, 2010
    Williesburg, Virignia
    You are good. In the future, I suggest you make sure to note on the new physical long form you have a current physical. This alerts the new examiner that you have one and saves you from losing both for doctor shopping. As to your question the FMCSA only allows one active physical to be in the system. Once the last physical was entered into the database it killed the first one.
    Now if I am misunderstanding your question and you are asking about a non-DOT physical then yes your old card is still good.
    x1Heavy Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I used to carry the original 2 year or whatever it was as a strict defense against bungled Physicals as happens from timt to time.
    To learn that the original effort is "killed" int he system when you present the second one...
    IF physicals are treated with respect that Drivers Licensing is treated with these days, then it should ut way down on the driver exams.
    The reason I am difficult about those things is because no one in the Industry respects those physicals that already exist and are valid. Why do we even bother spinning forms, wasting doctors time, throwing money around buying Apena crap and so on so forth etc.
    HoneyBadger67 Thanks this.
  7. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Yes,toss the old one...its not important anymore.
  8. Truckermania
    Truckermania Road Train Member
    1,185
    1,804
    Oct 13, 2011
    Sturgis,SD
    Submit your new one to the DMV and go with that one.
