Double Clutching advice no manual experience..
Discussion in 'Questions From New Drivers' started by RedTheTrucker, Jul 7, 2015.
  1. RedTheTrucker
    RedTheTrucker Light Load Member
    50
    17
    Jun 28, 2015
    Hey guys yesterday we did our first try at driving and i suck at double clutching downshifting really i was nervous asf first off i never driven a manual didnt know #### about gear gears pattern or double clutching
    the trainer in the classroom last week didn't put to much emphasis on learning the pattern because everyone in my class drove manual before besides me so i guess every body but me all ready knew how important it was except for me but since then i remembered the gear pattern on a 10 speed
    I have a couple of questions for you guys and if you have any advice im ALL EARS
    1. How do i load the clutch correctly? like When im starting or stopping do i raise my foot off the clutch before brake or brake before clutch ?
    2. If i missed a gear or got in the wrong one whats a good way for me to get in the right one? While downshifting and upshifting
    3. If i have to stop while in a high gear (with the clutch and brake pedal in) could i jus downshift to a low gear without double clutching or anything else
    I know some of these questions might sound dumb to you guys but i am completely new at this any advice is welcomed thanks
  3. ZhenyaP1991
    ZhenyaP1991 Medium Load Member
    573
    702
    Nov 6, 2014
    Asking too many question. Give it a little more time. You overthinking it. Ease up on the gas pedal, best advice I ever got.
  4. FozzyNOK
    FozzyNOK Road Train Member
    2,482
    3,826
    Jul 18, 2007
    Oklahomistan
    You downshift to a lower gear until you get to 5th (most common) and you play the light or traffic, if you must stop, wait until you are about stopped and or the engine begins to lug.. push in the clutch and stop,, or as the light changes and or traffic begins to move, slowly apply power and begin to upshift again.
    This will happen... it happens to everyone.. the best advice? learn the pattern and learn the speed ranges for the gears.. if you get lost or come out of gear, look at your speed, know which gear "represents" that speed.. raise the RPMs a little and "go for it" it may not be pretty.. but eventually it will get smoother.
    If you stop in a high gear (you'd have to coast to a stop... not good), just push the clutch ALL the way in.. select a starting gear (3rd) and start all over when you can safely start.
    Just breathe... while shifting talk to yourself! Out loud is best! When rolling you "tap" the clutch.. like testing a hot iron! TAP -neutral-TAP-shift. get the plunger out.. draw a shift pattern on a notebook and practice moving a shift lever.. a potato makes a swell clutch...
    Dumdriver and RedTheTrucker Thank this.
  5. AModelCat
    165,311
    Just keep practicing. It takes time to get the feel for it. The biggest thing is to keep calm and don't panic when you miss a gear. If you start getting stressed, it makes everything that much harder. Just keep in mind that no one expects you to shift flawlessly the first few times out.
  6. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    Just want to say this...
    There's only one kind of dumb question. The kind you didn't ask.
    You're not the first to ask about shifting and have trouble with it. So let me assure you that you most certainly won't be the last.
  7. rambler
    rambler Road Train Member
    1,358
    582
    Nov 5, 2007
    This is a question you really should be asking your trainer/teacher. Besides it's much easier to be shown and explained instead of trying to understand from words only thru an internet forum. To even ask this question when you have a trainer available is beyond my understanding.
    Good luck.
    Vilhiem Thanks this.
  8. Vilhiem
    3,992
    10,904
    Oct 6, 2014
    I know. I kinda feel the same way. If I had to guess, it's easier to ask a group of unknown people and be anonymous over asking the person who knows you.
    But it's a guess. And I certainly have been wrong before.
    rambler Thanks this.
  9. marineman227
    marineman227 Dock Waterer
    600
    796
    Jan 26, 2008
    Neenah, WI
    At a stop I come off the clutch just until it starts to catch then release the brake then come the rest of the way off the clutch. That will keep you from rolling back which I believe is an automatic fail.
    In a semi it's doubtful that you'll get the wrong gear since the road speed and RPMs have to match up. If you miss one and you're on flat ground go back to the gear you were in before and adjust the RPMs around your previous shift point and it should go back in. Pointing uphill drop a gear from where you were, downhill go up a gear.
    Yes at a stop you can just push the clutch once and come out of any gear and go into any gear.
    Shifting these things is all about timing and getting in a rhythm with the truck. It takes some practice but once you get the feel for the rhythm there's really nothing to shifting. If you're doing the plunger practice pull up a YouTube video of someone shifting a 10 speed and shift with him so you're getting the rhythm in your practice.
    powerhousescott Thanks this.
  10. MM71
    MM71 Heavy Load Member
    760
    992
    Jun 28, 2008
    AZ
    Youtube is your friend.
  11. powerhousescott
    powerhousescott Medium Load Member
    496
    499
    Jun 17, 2015
    Pecuiar, MO
    Maybe he is nervous around the trainer.
    I took a driver out that had been driving 20 years and he was scraping every gear. I asked him what was wrong, he stated that after watching me drive the truck that he was worried that I would not like his shifting. I had to take us back to the office. Jump in my suburban have him drive in front of me and watch the trailer as he shifted. We went back to the office, went back out in the truck and he did great. It is amazing how just being nervous can make the best driver seem like a rookie. My advice to the young man is to remain calm, we all scrape a gear or two here and now. We all went through the same thing, and he will get it. I am with the rest of you, better to get it from the trainer, but I thought the Youtube video was a good idea as well. Good Luck Rookie.
