Double Clutching Help Please...
Discussion in 'Questions From New Drivers' started by CWiLL23, Jul 24, 2012.
  1. CWiLL23
    CWiLL23 Light Load Member
    125
    41
    Jun 23, 2012
    Detroit, Mi
    I am only on my second day of training and I'm getting frustrated and I'm trying to remain calm and get this double clutching down packed, but I keep screwing up and I'm losing my confidence. The school I am attending does not have a driver simulator they threw us right in the truck and told us to get to it.
    I am not sure if it's me or the truck, but shifting the gears is no easy task I have to fight with the shifter to move it from 3 to 4 and when I go 4 to 5 I tend to not keep pressing to the right so sometimes it jumps back to 3.
    If you guys can provide any tips or advice that would be great.
    Thanks in advance!!
    Frustrated Trucker
    Cpaige304 Thanks this.
  3. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    what rpm are you shifting at? And what type of transmission and engine we talking about?
  4. ipogsd
    ipogsd Heavy Load Member
    977
    515
    Jun 13, 2012
    Shift forward and to the right with you palm, back with two fingers and thumb. I heard a good analogy about clutching. Just as you throw a jab while boxing, you jab the clutch, instead of pushing it. RPM's are critical as well.
  5. CenutryClass
    CenutryClass Road Train Member
    1,539
    859
    Feb 15, 2006
    watch some youtube videos to get the hang of it.
    know the shift pattern by heart.
    if you wait too long to shift, it will be difficult to catch the next gear
    double clutching is a three step movement:
    clutch in, move lever to neutral
    clutch out
    clutch in, grab the next gear
    Getting in the truck with it not running can help as well. Mimic engine sounds with your mouth and try getting the timing down. It works, thats out I learned along with watching boobtube videos.
    If trying it with the truck not running you might not be able to get it in some gears, but just pretend it is.
    Good luck
    CWiLL23 Thanks this.
  6. CJ5 Susan
    CJ5 Susan Bobtail Member
    41
    8
    Jul 24, 2012
    The Garden State
    Have you ever driven a manual transmission before? Just wondering. I will be starting my CDL class a classes next week.
  7. aiwiron
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    What I learned on
  8. FozzyNOK
    FozzyNOK Road Train Member
    2,482
    3,826
    Jul 18, 2007
    Oklahomistan
    No training like the real thing! The simulators are decent for practice, but inside the truck is where everything has to come together with the sites, sounds, feels and movement of the real world.
    Know the pattern! if the instructors or school will let you, sit in the truck and run through the pattern until you have a good idea where the gears are.
    Know that you have to tap the clutch. Think of the clutch as a hot iron.. that kind of hot! You are only tapping the clutch to break torque for a fraction of a second! To do this you need to "hang the leg".. you are "stabbing at the clutch" from the hip with your toe if that makes any sense.
    Wear light shoes! Heavy boots are great and even a requirement for some jobs. Learning to double clutch with heavy boots on is like trying to pick your nose with boxing gloves on!!
    When your hand moves the shifter, the leg moves at the same time..
    Recite (out loud helps!!) Tap - Neutral - tap - shift... kind of like a mantra..
    know that the lower the gears the quicker the shifts have to be done.. the shift from 3rd to 4th are really quick.
    RPMS higher than you need in the lower few gears is your enemy! Use gears to get speed.. NOT the accelerator! keep the RPM's as low as possible.
    This will fall into place for you, you just need to try and relax, observe, and BREATHE... This isn't hard, this is just NEW to you.
  9. CWiLL23
    125
    41
    Jun 23, 2012
    Detroit, Mi
    Thanks for the quick replies guys all of them have been helpful and I am going to give it all I got again tomorrow. I will update in a few days.
  10. Cpaige304
    Cpaige304 Bobtail Member
    33
    9
    Feb 18, 2012
    Fairmont wv
    I have only been driving for a few months and I had a hell of a time learning to shift you just need seat time and one day it will just all come together one thing that helped me was up shift at around 15 and down shift around 10 but give it some gas on the down shift right after you get it in neutral. Don't get discouraged and stay calm I noticed once I got used to being in a big truck my shifting became easier dont give up and good luck brother.
  11. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
    What type of tranny, how many gears??
