Double overdrive transmissions
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by alfio, Dec 17, 2023.
  1. alfio
    alfio Light Load Member
    63
    33
    Jun 2, 2021
    hello all,
    accumulating parts for a swap and i'm looking for double overdrive transmissions. what's out there in a double over? 13 speed would probably be good enough for what I'm doing but more important is the size of the transmission (need to keep it compact / small). would appreciate ideas.
    thanks
    a.
  3. W923
    W923 Road Train Member
    1,343
    4,093
    Feb 28, 2022
    What’s it going in
    most modern od 13 speed are double od
    .8 and.73 top ratios
    Oxbow, alfio, Last Call and 1 other person Thank this.
  4. alfio
    63
    33
    Jun 2, 2021
    It's going in a medium duty truck, prob International 4700 or a Ford, haven't decided the truck yet but it will be powered by an International DT360. I know what I'm planning would be ok with a .73 gear ratio, not sure how to figure out if a steeper overdrive would work or not.
    Define 'modern'? What years am I looking for when I go to the truck yard?
    Thanks
    a.
    W923 Thanks this.
  5. W923
    1,343
    4,093
    Feb 28, 2022
    If you’re going into what I would consider a 2 ton chassis you should be able to use anything you want as long as you can get an sae #1 bell for that dt360. I don’t think a #2 is available for many of the trannys that are common (yes I can find out but let’s narrow things a little more first). I am thinking late 80s to current when I say modern. To my knowledge all of the rtlo 1xx13b transmissions are a double od. And I would consider that to be a good choice. Unless you want to get into the smaller stuff like a 6610 or 6613 ( which won’t help) all of the 13 speeds rated for 1850 and less torque are for talking purposes the same size and shape. As far as the rto6610, it with a #2 housing was a very nice setup in my 3/4 ton idi ford pickup back in the day. Yes it fit with only a 2 inch body lift…if I had modified the firewall and front of the transmission tunnel it would’ve fit without the lift.
    NightWind and alfio Thank this.
  6. alfio
    63
    33
    Jun 2, 2021
    ok just realized that we're also communicating about this on another forum (yes, the internet can be that small sometimes LOL). where is this truck, do you have a build thread or videos anywhere? sounds awesome.
    a.
    W923 Thanks this.
  7. W923
    1,343
    4,093
    Feb 28, 2022
    It’s sitting here at my shop in the middle of nowhere Illinois
    Unfortunately the engine took a dump and it hasn’t been on the road in a while
    I don’t believe there’s any pictures/vids on the internet. It was several phones ago so I will probably have to go take some.
  8. alfio
    63
    33
    Jun 2, 2021
    Pls do. It just so happens I have a perfectly good DT360 looking for a home, thinking about selling the Ford? LOL
    a.
    W923 Thanks this.
  9. W923
    1,343
    4,093
    Feb 28, 2022
  10. alfio
    63
    33
    Jun 2, 2021
    Check your PMs
  11. alfio
    63
    33
    Jun 2, 2021
    Still collecting info on double overdrive options. Needing to find a compact case with double overdrive - could be 9 speed, 10 speed, 13 speed, etc.
    Thanks!
