Double star tires
Discussion in 'Trucks [ Eighteen Wheelers ]' started by GMB, Jan 7, 2017.
  1. GMB
    GMB Bobtail Member
    22
    Dec 17, 2016
    hi guys, does anyone have any experience with double star tires ? We have 8 drive tires .. had those installed when we baught the truck and had the truck for about 3 months now. The truck has almost no shake when bobtail, shakes a little when we have the trailer empty, and shakes even more when loaded.. would anyone know if this has anything to do with those chinese tires ? Tnks
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Can you jack up the back to spin the tires fast enough to see if they are round?
    If not, take a couple off and put them on a balance machine to see if they are round.
  4. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    Bent rim, out of round tires, ride height?
  5. GMB
    GMB Bobtail Member
    22
    Dec 17, 2016
    We had already checked but didnt seem to be out of round
  6. GMB
    GMB Bobtail Member
    22
    Dec 17, 2016
    Rims are good, tires dont seem to be out of round, ride height is good also...
  7. AModelCat
    165,347
    One would think that if the tires were at fault, the shake would be worst bobtail and smoother when loaded. How is the ride height? Driveline angles good?
    Edit: I see you beat me to it. Did you check ride height loaded and bobtail?
  8. GMB
    GMB Bobtail Member
    22
    Dec 17, 2016
    Ride height is at 9 1/4" as per told by International dealer, drivelines angle not sure how to check ?
  9. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Most Chinese tires are known to be garbage.
    They usually aren't round or have issues with Balancing.
    Since you don't really know how the truck drove before the new tires were installed, it's now a matter of doing the process of elimination.
    The tires most likely are the culprit as when they start getting some weight on them, (such as a empty trailer and then a loaded trailer) the shake becomes noticably and progressively worse because the tires become more distorted and out of round.
  10. GMB
    GMB Bobtail Member
    22
    Dec 17, 2016
    We
    we're starting to think the tires are the problem too...
  11. Mattflat362
    Mattflat362 Road Train Member
    2,711
    6,323
    Feb 18, 2015
    Avon Lake, Ohio
    Bad tires are tough to diagnose and brand new bad tires ....ahhhhg! TA makes you buy another tire to prove it and then you have to wait for Yoko or whoever to come out and verify for a refund. NEVER again will I try to save money on tires and never again will I buy them far from home.
    Oldironfan Thanks this.
