Double Trailers; Heavier Trailer before Lighter Trailer 23 CFR
Discussion in 'Experienced Truckers' Advice' started by moloko, Mar 19, 2017.
  1. moloko
    moloko Road Train Member
    1,569
    1,376
    Oct 26, 2012
    seattle, wa
    It is written in 23 Code of Federal Regulations, regarding double trailers;
    "In the event that the gross weight of the trailers vary by more than 20 percent, they shall be coupled according to their gross weights with the heavier trailer forward."
    This is a policy in several states, such as Alaska, Ohio, Oklahoma. It is a question of great debate lately. My common sense tells me this is because of the 'crack of the whip' effect, or Rearward Amplification.
    I just wanted to get some experienced drivers advice on pulling double trailers with the first trailer closest to the power unit being lighter than the rearmost trailer. Don't ask me why I'm asking--that is too complicated. Just tell me, why you think this is a bad idea.
    Show me some examples of horrific accidents that have happened because of this, while you're at it.
    G13Tomcat Thanks this.
  3. G13Tomcat
    G13Tomcat Road Train Member
    11,872
    42,143
    Jun 7, 2011
    I pulled doubles for FedEx/Linehaul back in '03 .... and that's EXACTLY what they told me... then again, I'm out of Ohio. Was hauling to Cali and back once a week.
    @Mike2633 ??? @road_runner ??? @miss elvee ??? (our resident doubles gurus...btw.)
    I'd like to hear how this turns out... Really. Thanks for the post, man.
    DRAGON64, moloko and Big Don Thank this.
  4. moloko
    1,569
    1,376
    Oct 26, 2012
    seattle, wa
    California is more regulated than Ohio. I am trying to find a reciprocal statute however. I know this law is applicable to Ohio. Did they tell you, this is because of the crack the whip effect? And do you know if it was their actual policy, or just "common knowledge?"
  5. G13Tomcat
    11,872
    42,143
    Jun 7, 2011
    It was definitely the "crack of the whip" effect. I was legal in Ohio, and uncoupled, switched, and reloaded from Cali to here, the same way. Wish I could give more than that, but it's how I ran, legal both ways.
    In hindsight, it makes sense to me. Laws of physics; wish I could give you more. I'll look further into it, as time allows. I'm intrigued as well~!
    moloko Thanks this.
  6. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    Just a bit off subject here, (so what's new,) but the outfit I used to work for put together some really weird combinations. Like a tractor pulling a fuel trailer, with a box pup on behind it. One time, actually not very long ago, I saw one reversed, where the pup was the first trailer and the long tanker the second. I can only guess that the pup was loaded, and the fuel trailer empty. But these combinations sure do look weird.
    fargonaz, Mike2633 and G13Tomcat Thank this.
  7. G13Tomcat
    11,872
    42,143
    Jun 7, 2011
    from another thread, but more input from @bzinger and he knows his ####.........
    Heavy pup leads the pack tom .
    SteveBausch Thanks this.
  8. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    I haul crude oil in super b tankers. I can give you a example from my first year trucking.
    I pulled to a oil lease and loaded my lead with water then my pup with crude oil. Went to offload and there were 2 risers to unload at, it was easier for me to unload the water first then do a uturn to get to unload the oil.
    It was winter time, I was in a oil plant not going more then a couple miles a hour and when I went to do my uturn..... the pup being the heaviest just kept going straight, jackknifed the #### out of that unit. I was very lucky that I was going so slow and nothing hit so there was no damage but it taught me a lesson that day.
    Chewy352, crb, Just passing by and 5 others Thank this.
  9. moloko
    1,569
    1,376
    Oct 26, 2012
    seattle, wa
    Was this like, a truck and trailer?
    Just to give you guys a hint of what I'm up against at this time. I had to have a battle of the wits with dispatch, for refusing to operate an empty truck but loaded trailer down a major freeway, in the rain. Like what you are asserting, I was afraid that the heaviest unit would continue pushing forward, increasing the risk of a jack-knife. To compensate, I'd have slowed down to like 25 MPH in a 65MPH zone. Realistically, people would be driving 80 MPH at least--I've even seen people drive this freeway over 100MPH. It's a major freeway in one of the largest major metro areas in the USA.
    The rear compartments were empty of liquid. But they were full of vapor, which is volatile and explosive. Let's say I'm cruising down the freeway at 25MPH with flashers on. Some idiot rear ends me doing 80MPH. The discrepancy of 55MPH in a rear-end scenario, causes the driver to drive right into my empty compartments. This would probably lead to an explosion of a catastrophic nature. This would cause the other 2000 gallons to catch fire too. Frankly, this would have probably killed me and been on national news.
    The first compartment was fully loaded with 2000 gallons. This is about 12330 pounds on the front axle only, while the rest of the vehicle was completely empty. Now, some states have a regulation that state, the rear trailer cannot be more than 20% heavier than the front trailer. We also cannot have more than 20,000 pounds on any one axle. By my calculations, the empty truck and trailer combo weigh about 20,000 pounds. Loaded in this manner, it is about 32,000 pounds--an increase of over 65% of the entire truck's empty weight--and all of that weight is in one compartment, on the front axle only, in the rear trailer. Somebody please tell me why this is a horrible idea, outside of our own common sense.
    Think about it. That 2000 gallons of fuel itself, probably weighed 12330 pounds. The fuel itself, is probably heavier than the entire weight of the front power unit truck and tanker, when empty. It doesn't get any scarier than that.
  10. dustinbrock
    1,308
    901
    Apr 19, 2012
    These are a couple of mine. Super b.
    G13Tomcat and moloko Thank this.
  11. moloko
    1,569
    1,376
    Oct 26, 2012
    seattle, wa
    Thanks Dustin. It also looks like it might be a bit more unstable than a typical fuel tanker truck/trailer setup, because you have a 5th wheel on that first tank, am I correct? So it's another pivot point.
