down shifting 10 speed
Discussion in 'Questions From New Drivers' started by Horse, Oct 2, 2010.
  1. Horse
    Horse Bobtail Member
    I have a nagging question about down shifting. I am not a driver yet but have been around some drivers. I was in a truck and the driver told me this -but I can not find any info from eaton or spicer or other manufacturers-. The driver said when downshifting from H range to 1st gear he has to go through 5th low before he can skip shift down to 1st. He showed me this: he came to a stop in 9th gear (high range) he shifted the range lever to low and tried to shift into 1st and the gears ground. He could not shift, he had to go back and pick up 5th grear before he could skip shift down to 1st.
    He said he always has to pick up 5th gear when skip down-shifting even when moving or the range control will not shift properly. Does anyone know what I am talking about?
    At standstill I think the clutch is spinning and no clutch brake.
    Respectfully
    Horse
  3. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    If I am sure I am going to stop I go into neutral as I am coasting down, then while slowing at about 3 MPH you can slip it into your starting gear 2,3,or 4 as the RPMs match and depress clutch before you stop.
    If you may need to take off without stopping completely you should split down. So you don't get lost.
  4. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    the road less travelled
    Moving the shifter across the pattern is what actually switches the range when the selector is switched, moving the selector merely selects it. Did you mean from 6th to 1st?
    With your air pressure built up, try shifting without the engine running, switching the range makes whoosh sound(a weak one anyway), but when you move the shifter across neutral, you will hear the transmission being shifted, you may also feel it.
    I drove a really heavy duty 9 speed an a converted fertilizer applicator in 2004; shifting the range in motion with the engine running could be heard and felt.
  5. Allow Me.
    10,769
    12,593
    May 28, 2009
    Rancho Mirage, Ca.
    :mconfused: I think I understand, sometimes you can't get into 1st, when that happens, shift into 4th or 5th ( it won't grind) then back into 1st (easy as pie)! But, i gotta say, if he's using 1st gear, especially when empty, he's in-experienced.
  6. Capt_Gruuvy
    Capt_Gruuvy Light Load Member
    264
    94
    Jul 29, 2010
    Middle of the Desert
    It's all about RPMs.
    Unless you are hauling 80,000 you may want to leave 1st out of it.
  7. Trick Daddy
    Trick Daddy Bobtail Member
    37
    Sep 13, 2010
    Loves Park, IL
    Sounds like a straight ten, I have driven that trans, and you just need to get the range selector down and select the right gear...5, 4, 3, uh, 2 or 1...that seems a little slow for a downshift to begin with. Downs from 6th to 4th are pretty common in our group (class), so there is no need to get 5th on the way down...no. The splitter (range selector) just needs to be down when you go through neutral into the lower gear. Most of us (in our class) just drop it when we are in the higher gear so it's a simpler motion for downshifting. Just remember that you have that thing down...if the light changes and you don't need the down, you may find yourself trying a 7th to 3rd gear shift if you forget it....lol.
  8. Horse
    By 1st I meant 1st gear above his creeper gears. All that information is standard according to eaton transmission web site. He said he would shift 1l 2l 3l 4l 5l then high range repeat the pattern but with preselecting the high range and to down shift to low range he could skip to 6H but to skip to a lower gear such as 4l he would have to go through 5th(lo range) gear to keep the range control from grinding gears.
    I hope I am not confusing anyone. I mean 1L = 6H with range control on high
    2L=6H 3L=7H this is with out using any OD/UD splits just the range control.
    I don't have access to the truck anymore.
  9. Bent Wrench
    588
    205
    Aug 11, 2009
    Cornholio, OR
    Unless you are at max load and going up hill you probably are not going to use Lo, 1 or even 2.
  10. Horse
    I am looking at the Fuller Roadranger instructions and they post no caveats about skip shifting from high range down to low range gears 1,2 or 3 skipping 4th. Maybe I misunderstood.
    On my side there are so many different models and variations or maybe his transmission was hard shifting and going through 4th gear or 5th seemed to work.
    Thanks for all the reply's
    Actually I have had a CDL for many years just not a class A
    I am kind of looking foward to see a dump truck driver haulling a 10,000# plus trailer get arrested for not having a class A license.
    Thanks.
