down shifting ?
Discussion in 'Questions To Truckers From The General Public' started by steven73, Aug 3, 2014.
  1. steven73
    steven73 Bobtail Member
    28
    4
    Jul 16, 2014
    What's up guys, so say ur on the road in 10th gear and ur coming to a stop light do u start to down shift or does anybody just stay in 10th gear and while u are stopped take it out of gear and put it into one of the lower gears before u take off? Sorry if this is a stupid question, but I've seen a video where a guy stops at a stop sign and he is in 5th gear and while he is stopped he takes it out of 5th and puts it straight into 1st is this possible? Does this work or are u not suppose to do it this way?
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    If the stop was sort of unexpected like a light changed as you were about to go through it, you may not have time to down shift, meaning you have to do 1 of 2 things, mash the clutch and brake to a stop, then select your preferred gear, or take it out of gear then brake to a stop.
    There are multiple stopping scenarios and each one is typically handled a bit differently, as per the situation and/or as per the driver's style or particular mood at that given moment.
    steven73 and JReding Thank this.
  4. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    In a panic stop ( 4-wheeler stopping for a light without checking what's behind him or the like) , I will gear down and brake till I can't, then just before the truck stops moving, flip it to low and catch first (or low).....
    My 8LL HATES range shifts sitting still.....hard to sync gears that aren't turning
    My .02
    steven73 Thanks this.
  5. chris886
    chris886 Medium Load Member
    531
    286
    Aug 22, 2013
    Chicago, IL
    best to downshift if you have time. for a sudden stop brake and clutch or brake and nutral. then find the gear you need
  6. fireman5523
    fireman5523 Light Load Member
    141
    106
    Feb 12, 2012
    Little Rock, Arkansas
    When you're stopped you can put it in any gear you want as long as you're on the clutch. You just can't take off from too high a gear. I drive a 9LL (aka 13 under) and when I'm empty I start off by splitting 4th.
    Davem3TF and steven73 Thank this.
  7. camionneur
    camionneur Road Train Member
    1,239
    760
    Oct 18, 2013
    Automatic trucks are this way, even if I go into manual mode and downshift to 4th at a stop, it then shifts itself into 2nd and makes me pull an empty really slow when I'm trying to go left with oncoming traffic. Quite the retarded situation, and I question how this conserves fuel (well, pick your battles... I'd have to go with a higher paying job in an automagic truck, that pulls the rug out from under me, and let it "win", slowing everyone else down too).
    I don't know, it's trial and error and I've only driven them a few times (without an owner's manual), mainly trying not to roll backwards without a clutch to load, so maybe if I switch into the low setting it will let me start in a higher gear, that would be ironic, if I get stuck in one again (not sure if that's equivalent to low range, might just be, not that there's a high range per se). The key to any transmission is not stopping until you bump a dock...
    :biggrin_25523:
  8. Darkstorm824
    Darkstorm824 Bobtail Member
    Chippewa Falls Wi
    I do it that way i kinda annoys the liven heck out of the instructors though, as for the truck i don`t think it hurts it none.
  9. kemosabi49
    11,013
    48,109
    Jan 13, 2013
    SW Arkansas
    Panic or regular stop. Either one I will slide it into the gear I need to start as I roll to the complete stop. That's just what I was trained to do. I don't really think there's anything wrong with stopping, then finding the starting gear either. Either way is fine.
  10. JReding
    JReding Road Train Member
    1,957
    3,512
    Sep 8, 2014
    Puyallup, WA
    It depends in the scenario, but under normal circumstances, I downshift, but not every gear, it's overkill in my book. I will typically skip shift down (2 or 3 gears at a time), until I'm down to 5th or 4th gear.
  11. Aditransport
    Aditransport Light Load Member
    111
    21
    May 19, 2012
    Colorado Springs, CO
    All depends on how fast you need to slow down or stop. I use my left foot on the brake, right foot on the gas and downshift using the jakes to slow the truck down. I can go from 10th to 6th in a matter of seconds and save my brakes a whole bunch. That brings be down to 10 mph. If you know your truck like you should, then you will know what gear to go into if you don't have to come to a complete stop. And shifting to low gear while stopped does not hurt anything. If it will not go into gear, ease up on the clutch pedal a little so the input shaft turns a little and lines the gears up so you can shift it.
