Downshifting going uphill
Discussion in 'Experienced Truckers' Advice' started by TooTiredToTalk, Apr 7, 2022.
  1. TooTiredToTalk
    TooTiredToTalk Medium Load Member
    636
    2,935
    Feb 24, 2022
    Okay....so those of you that have seen my prior posts know I've been learning on an 18-speed. My boss just messaged me saying that I might need to drive down South to help him out. I haven't had to drive uphill yet.....I am kinda nervous. How do you shift while going uphill downshift like when loosing too much speed and upshift??
  3. MACK E-6
    50,105
    239,092
    What kind of engine you have?
  4. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    I think I know why they took the shift bars out of them now.
    JolliRoger and Swine hauler Thank this.
  5. staceydude
    staceydude Road Train Member
    1,151
    5,041
    Apr 3, 2020
    No expert at all really but…
    I watch all the gauges and listen to everything going up hills that really need to be thought about.
    Start losing power/rpm your egt tends to rise and even though you might feasibly make it up some hills you have to think is it really worth putting that extra strain on the engine so just drop a gear and bring the rpm’s up a bit and your using your gearing vs all your engine grunt. Your egt will drop and you have an easier time pulling a hill without causing any unnecessary strain, if you reach the top and your lugging it at 40 mph vs using all your tools at 25 it is just better for your truck. So you start feeling yourself coming out of the power band, downshift and bring it back into optimum range. You can climb some pretty nasty stuff and your engine is just as happy when you get to the top as it would be any other day if managed correctly.
    Then setup and be in a proper lower gear for the descent so you don’t have to downshift going down. Start down slow.
  6. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,896
    Nov 26, 2020
    If you’re moving a Detroit 60 my truck likes riding the gear up to about 20-22 rpm so that it catches smooth at 14-16 rpm.
    TooTiredToTalk Thanks this.
  7. TooTiredToTalk
    636
    2,935
    Feb 24, 2022
    I don't know the mechanics and all, but my truck has a CAT engine in it. That's about all I can say regarding the engine.
    MACK E-6 Thanks this.
  8. TooTiredToTalk
    636
    2,935
    Feb 24, 2022
    What is egt?
  9. MACK E-6
    50,105
    239,092
    Well, if your kitty is anything like my Cummins, it likes running between 1100 and 1450. If you’re cruising on the bottom end of that range drop a gear as soon as you hit the grade, and if it isn’t too steep you can climb the entire hill at half throttle.
    Your engine will appreciate that.
    JolliRoger and TooTiredToTalk Thank this.
  10. idriveaholden
    idriveaholden Super Heavy Hauler
    708
    2,236
    Mar 14, 2018
    it just takes practice and knowing your truck
    Go figure out what engine you have and google the power curves.
    JolliRoger Thanks this.
  11. rockeee
    rockeee Medium Load Member
    338
    654
    Apr 22, 2015
    Kalama, Wa
    And...if you can shift on the flats you can shift uphill, it's just going to happen a little faster
    JolliRoger and goga Thank this.
