DPF cleaning, "WG" rating, etc
Discussion in 'Trucks [ Eighteen Wheelers ]' started by fooomanchu, Jan 17, 2013.
  1. fooomanchu
    fooomanchu Light Load Member
    63
    8
    Oct 19, 2012
    Urbana IL
    I recently had my dpf removed and cleaned.... Apparently there is a rating they use for how dirty or clean it is. Mine was a 3.5 dirty and then a 2.5 after they cleaned it. I tried to find info about this number on the web but didn't have any luck. Can someone explain this or direct me to where I can learn more about this number and the process in general? I'd like to be able to know when I should get the dpf cleaned and when I need to get it replaced.
    Also it seems that the Freightliner filters are about $800 while the Cummins filters are $1800... I'd like to know if this info is accurate and if so, why the huge difference in price! :)
  3. dloving8915
    dloving8915 Light Load Member
    213
    68
    Sep 18, 2010
    Dallas, Texas
    We just had the DPF cleaned as well. Not sure what the WG is I believe it is weight. The shop in Ca weighed the filter befor the baked/cleaned it and after. My guess would be that they were able to remove a pound of ash from your filter! We priced a new filter from Donaldson It was $1000 new for our 09 Peterbilt with a cummins.
    fooomanchu Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    WG is "water gauge", or difference in pressure across the filter in inches of water. The number is basically how plugged the dpf is. They will measure this before and after the cleaning procedure to see if the dpf is any good to reuse. All dpf models are different, but generally they are all in the same ballpark for readings. New have a wg of about 2.25, ok to reuse about 2.5 to 3. Over 3.5 to 4 is plugged.
    There is always price differences going from manufacturer direct and other suppliers. 3rd party parts suppliers are producing DPFs now. Make sure you shop around if you need a replacement.
    Check out this link from FSX for the wg ratings.
    http://www.fsxinc.com/site1/BaseLinesNScience/CurrentBL.html
    25(2)+2 and fooomanchu Thank this.
  5. fooomanchu
    63
    8
    Oct 19, 2012
    Urbana IL
    Hey thanks. Yeah it looks like we did the smart thing cleaning as opposed to replacing....I was told by a few people NEVER clean, always replace, but the tone of their voice sounded kinda shifty and I went with my instinct to clean! I'd check my paperwork if I were you and see if they gave you a wg rating before and after just for reference. Thanks for help!! :)
  6. fooomanchu
    63
    8
    Oct 19, 2012
    Urbana IL
    Oh ok GREAT, this is what I was wondering.... The numbers were confusing to me because I would have expected 1 to be a good number and 5 to be bad but it is obviously not that simple! I checked out the link you gave and it was very helpful...thanks a lot!! :) Tell mr. t i said hello
    Heavyd Thanks this.
  7. Heavyd
    7,826
    6,276
    Feb 4, 2009
    I pity the foo that doesn't clean his DPF, sucka!
  8. Cat sdp
    Cat sdp . .
    21,309
    76,241
    Apr 8, 2012
    Orion's Belt
    Comments like this show that you have no idea how much pain the manufacturers and their agents the dealerships have inflicted on us. Which is why I'm on your back a lot.
    The only reason we are a ( sucka) is because we Bought these pos!
    Tell the truth, these trucks are the best thing that ever happened to dealership service depts. Right.
  9. fooomanchu
    63
    8
    Oct 19, 2012
    Urbana IL
    hahahahahahahahahaha!!!! :)
  10. fooomanchu
    63
    8
    Oct 19, 2012
    Urbana IL
    I think he was kinda just goofing around in response to my "Mr T" comment, which was a response to his A-Team userpic :)
    Cat sdp Thanks this.
  11. Cat sdp
    Cat sdp . .
    21,309
    76,241
    Apr 8, 2012
    Orion's Belt
    Never watched the show. Sorry for jackin on your thread. Hd helps a lot of guys on here, but we've had a few go rounds on this issue........ I over reacted as usual .
