DPF cleaning
Discussion in 'Questions From New Drivers' started by S Trans, Apr 15, 2016.
  1. S Trans
    S Trans Bobtail Member
    Does anyone know any DPF cleaning services in Mooresville IN or around that area, thanks
  3. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    All your common places, considering how close you are to Indy. Truck Dealers, Diesel engine repair shops, some of the big truck part dealers have their own ovens as well. You would be best off calling some local companies and asking where they get theirs cleaned at.
  4. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    It's true a lot of places say they can do the work, but that DPF system is complicated, and that filter is Expensive. Maybe your factory shop can refer to a reliable outlet?
  5. t660man
    t660man Bobtail Member
    22
    17
    Jul 1, 2013
    You can go to the dealer and do an exchange program. I have one with my local freightliner where they take the old one and just put in a new one. It's cheaper
    Starboyjim Thanks this.
  6. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    Is your truck throwing up any fault codes pertaining to the aftertreatment system? Because that'll be the difference between wanting to just get it cleaned and reinstalled and having a more in-depth diagnosis - where they'll inspect the dosing injector for leaks and flow rate, check the aftertreatment fuel shutoff valve, etc., etc. - to be done. Any shop can drop a DPF, send it off to be baked, and reinstall it. Actual diagnosis and corrective action to prevent an issue from recurring is a different matter.
  7. Maxxforce 500000
    Maxxforce 500000 Bobtail Member
    22
    How do you know when your filters need to be cleaned or exchanged?
  8. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Manufacturers have recommended cleaning intervals. If you don't follow them you take a chance like my current boss, $9k in repairs and now in for another $4,700 today.
