Drag link help?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by manleyman, Feb 18, 2024.
  1. manleyman
    manleyman Bobtail Member
    15
    15
    Oct 4, 2020
    I have a 1989 Peterbilt 379 EXHD. I bought a complete 20K dual steer box front axle cutoff. It was suppose to be what I needed to drop my axle out, bolt on boxes and install springs and axle. But that is not the case. I was sent set back axle front end. I'm going to use the top springs of my old stack to make spring work.
    The issue I'm having is coming up with the draglink for the righthand side. So was trying here to see if someone here could supply me with a part# or vin# to use to find the correct part.
    Would appreciate any help. Thanks Manley
  3. Last Call
    Last Call Road Train Member
    7,568
    45,913
    Mar 15, 2021
    Probably gona need a model # and a vin # from the cut off in order to do a parts search
    Bean Jr. Thanks this.
  4. manleyman
    15
    15
    Oct 4, 2020
    The drag links that came with cutoff are to long because it is a set back axle. Mine is standard set forward axle.
    Bean Jr. and Last Call Thank this.
  5. Last Call
    7,568
    45,913
    Mar 15, 2021
    I don’t have the actual capability to look up Paccar parts but Suspension parts a lot of times I do a Google search and can find aftermarket part numbers that cross reference to Paccar #s you going to have to know the manufacturer of your axle
    Big Road Skateboard Thanks this.
  6. AModelCat
    164,923
    Worst case Ontario you could probably just measure the length and find an adjustable one that fits. Hopefully it doesn't need some funky bend in it to clear the tires.
  7. manleyman
    15
    15
    Oct 4, 2020
    It looks to me like the factory left hand drag link will be the correct one. But haven't been able to come up with the right hand side drag link #.
    It's the same length as LH, just ends are turned opposite direction.
  8. Last Call
    7,568
    45,913
    Mar 15, 2021
    Then it probably would would be the same drag link you just set the end’s different to fit the right hand side
  9. manleyman
    15
    15
    Oct 4, 2020
    These drag links aren't threaded to be able to turn ends. They are molded with bends and tie rods in a set position.
  10. SmallPackage
    5,813
    18,627
    Dec 20, 2019
    Marion Texas
    Do you have access to a 379 of that generation that is set up the way you are trying to accomplish? Doesn’t have to be exact year but same basic model and configuration within maybe a 5 year range. Using that trucks vin my get you in the ball park and closer to the right direction for part #’s. This is kinda what @Last Call was getting at.
  11. Last Call
    7,568
    45,913
    Mar 15, 2021
    Then that’s easy there will be a right & a left drag link
    You really need to contact a Peterbilt dealer and explain what you are trying to accomplish and you better have The last 6 digits of your ViN # when you are talking to them and the axle manufacturer also
