drivability
Discussion in 'Freightliner Forum' started by Glenn West, Sep 1, 2020.
  1. Glenn West
    Glenn West Light Load Member
    88
    37
    Apr 22, 2016
    I have never driven any other truck. So I don't know how good they should drive. Takes both hands to keep mine straight on road and it still wanders. People have told me its the front air bags. Others tell me they can drive with one finger. I'd be in the ditch. Kingpin bushings installed, 4 wheel alignment done. All stearing components good. I didi tighten the steering box some and it may need more.
  3. 062
    062 Road Train Member
    6,338
    33,982
    Oct 20, 2013
    Worn drag link,tie rod ends,rear sway arm bushing. You just have to eliminate one thing at a time.
    alds Thanks this.
  4. Glenn West
    88
    37
    Apr 22, 2016
    All you posted checks out good.
  5. 062
    6,338
    33,982
    Oct 20, 2013
    Have you checked out all the u-bolts?
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    How's the ride height. If it's out of whack it can make the ride pretty terrible
  7. AModelCat
    164,928
  8. Glenn West
    88
    37
    Apr 22, 2016
    It rides great. It wanders on road. Takes both hands to drive.
  9. Glenn West
    88
    37
    Apr 22, 2016
    I don't know about the caster. It drives like it has none. I paid a reputable shop to do 4 wheel alignment on it. He also replace kingpin bushings. Said everything else good. Some play in steering though. I removed most.
  10. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    If you have play in the steering that will definitely make you wander.
    If you have play in the steering fix it now because it's dangerous.
    Check your steering box all your linkages your tie rods and the shaft and U joints that come from the steering column.
    Whoever did your alignment should have checked the front end and all of the steering components.
    Can't tell you anything about trucks with airbags on the front axles.
  11. Glenn West
    88
    37
    Apr 22, 2016
    Is the dearship best place to check alignment? As far as steering play it is small. Had more until I adjusted it. It helped. Concerned might get it too tight
