Drive axel touches frame? Help!!
Discussion in 'Volvo Forum' started by newdriver2, Apr 17, 2019.
  1. newdriver2
    newdriver2 Light Load Member
    97
    87
    Sep 14, 2017
    I have a 07 Volvo vnl670 and when I'm heavy loaded 40,000+ my axel will kiss the cross member behind cat walk into the differential....
    When my bags are dropped fully the u-joints on the drivetrain will touch that cross member???
    I've replaced both torsin arms ...what could it be?? Every mechanic I've talked to is stumped ...pic attached
  3. Farming Trucker
    Farming Trucker Bobtail Member
    41
    45
    Mar 30, 2019
    Not sure the answer but that’s definitely a problem.
    newdriver2 and Bean Jr. Thank this.
  4. 062
    062 Road Train Member
    6,328
    33,968
    Oct 20, 2013
    @nasriza @BoxCarKidd will have a idea. My guess would be loose or broken u-bolts allowed the axle housing to rotate. Has it been like that long?
    newdriver2 Thanks this.
  5. dumptruck89
    dumptruck89 Light Load Member
    79
    106
    Feb 27, 2015
    MA
    Are there bump stops on the frame? Or possibly a spot were they should be?
    newdriver2 and magoo68 Thank this.
  6. newdriver2
    97
    87
    Sep 14, 2017
    nothing is broken on the axel or u-bolts... i did two Kentucky to St. Louis loads this week which were 35,000lbs without any trouble.
    when I picked up a 40,000lb load the axel was close to the cross member and would kiss and touch when i drove it (30 ft after declining the load)
    - the axel also touches (in the picture) when the bags are dropped.
    - i'm not sure how long it has been like this, i just got the truck a month ago? and I have not had many heavy loads...
    - truck drives fine under light load. 70mph all the way, acceleration is good
    ** I'm thinking maybe someone put plates under the leaf springs on the rear for an alignment? maybe raised the frame? or something to that aspect?
  7. newdriver2
    97
    87
    Sep 14, 2017
    that was literally on my list to look at tomorrow - the truck is at a local shop right now. I do not recall seeing any bump stops or spots where they should be on this volvo.
  8. 062
    6,328
    33,968
    Oct 20, 2013
    Were the bags dumped in that pic? I’m not familiar with Volvo’s, but I wouldn’t think it should be that close even if they were.
    newdriver2 and flood Thank this.
  9. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Take lighter loads!
  10. newdriver2
    97
    87
    Sep 14, 2017
    Lol yea I know. I'm thinking 35k is my limit should have bought a pete
  11. newdriver2
    97
    87
    Sep 14, 2017
    Yes bags were dumped in that pic, HOWEVER when fully loaded with 40k or more it sits there just like in that pic
