Drive axel touches frame? Help!!
Discussion in 'Volvo Forum' started by newdriver2, Apr 17, 2019.
  1. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    spend the money and run the vin on rig dig. it will show you all kinds of stuff. violations, accidents, owners, etc
    newdriver2 Thanks this.
  3. newdriver2
    newdriver2 Light Load Member
    97
    87
    Sep 14, 2017
    Paid the money for the rig dig report. The only thing it told me was previous driver was an ### hole. 3 speeding tickets and a following too close ticket...he was doing 88mph in ohio
  4. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    what are the 3 inspections for
  5. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    the speeding must be the 4 inspections. whats the blue
  6. newdriver2
    97
    87
    Sep 14, 2017
    It's weird how they tie it together but these are the details on the 4 total inspections. They were all driver inspections which the driver got inspected for speeding each time so he got double stuffed lol
  7. newdriver2
    97
    87
    Sep 14, 2017
    Na
  8. newdriver2
    97
    87
    Sep 14, 2017
    I went thru every air connection today every fitting every bag...I found 2 air leaks. 1 being on a air tank valve that's now fixed, the other being on a fitting under the cab bag.
    Also found the bad/loose/bunked up 4x4 lock fitting
    Frame looks solid, no bag leaks, I noticed there is a drive train adjustment bracket ... that is sitting under the cab looking back (see images)
    PE_T Thanks this.
  9. newdriver2
    97
    87
    Sep 14, 2017
    Alright- after looking over everything, checking every hose and spending the majority of yesterday under the truck...
    My conclusion is that the rear springs are warn... it's the only thing that makes sense at this point.
    simple fix is swapping cross members but that will not help if a spring snaps
    PE_T Thanks this.
  10. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    just remember me if that is the problem.
  11. newdriver2
    97
    87
    Sep 14, 2017
    I drained all water in the air tanks, changed leveling valve, the valve tou mentioned before has obly a few thousand miles on it.
    What did I miss ?
