Drive axel touches frame? Help!!
Discussion in 'Volvo Forum' started by newdriver2, Apr 17, 2019.
  1. newdriver2
    newdriver2 Light Load Member
    97
    87
    Sep 14, 2017
    So, could my leveling valve be broke ? Not holding pressure and dropping the bags? Possibly the way it's sitting in the fine? Idk?
    flood, PE_T and Bean Jr. Thank this.
  3. Ruthless
    Ruthless Road Train Member
    9,191
    91,272
    Aug 28, 2010
    The City.
    Sure would be my first guess
    newdriver2, IH Truck Guy and Bean Jr. Thank this.
  4. newdriver2
    97
    87
    Sep 14, 2017
    Do you think the way that u-joints is sitting when bags are dropped is normal ? It is maybe a paperclip gap before hitting ...if the paperclip Is laying flat on a table
  5. Ruthless
    9,191
    91,272
    Aug 28, 2010
    The City.
    I wouldn’t think so: look at your leveling valve rod see if it’s connected, and see if it’s not broken. I’d think even with the suspension dumped the driveline wouldn’t be that close. Might want to check for stops in your suspension n make sure they are in the correct spot and at the correct height.
    newdriver2 Thanks this.
  6. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    This ^^^
  7. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    my money is on the springs. springs are wore out. shocks only keep the down force of the tire on the road. the springs carry the blunt of the weight. air bags added to the help the weight. if the ride height is correct with the lever valve then the springs must be wore out.
  8. newdriver2
    97
    87
    Sep 14, 2017
    Is that possible? For all 4 of the rear springs to be worn out ? How would I be able to tell ?
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Sorry but you have a botch job. The the picture you posted the the frame gussets on the right and the left are not the same. Never saw a cross member above a U joint like that which I recall. That truck has been stretched, patched or spliced and it was not done correctly.
  10. BoxCarKidd
    4,551
    6,641
    Aug 26, 2014
    More pictures please.
    newdriver2 and AModelCat Thank this.
  11. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    The air springs could be cracked leaking air or some leak in airline or valve, fittings they need to hold over 50psi to lift 40,000lbs load ; Did you hear your air compressor running nonstop, lossing oir pressure? or weak snapped springs or torque leafs.
    The air springs are sitting on Z springs rear end pushing against it to lift the frame, they work together, so I would check both air or Z spring / torque leaf combo, lose U bolt shifted axle.
