Drive axle(s) chatter when turning
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kubasj05, Jun 10, 2021.
  1. kubasj05
    kubasj05 Light Load Member
    148
    57
    Apr 18, 2013
    Hi everyone, having an issue with wheel chatter noise and vibration when turning left, right is ok.
    It only happens when empty, everything seems fine when loaded. I have recently did an 3 axle alignment and we weren't able to align forward drive Axle as we ran out of adjustment, rear axle barely made it, steer is good too. No worn-out bushings, no signs of broken springs either. Truck pulls to the right before and after alignment. I wonder if that chatter has something to do with the misaligned Axle since it does it (not all the time) when turning left. Print out indicates that left side of the forward Axle should be pushed towards the back of the truck.
    My major concern is running out of adjustment (this is eccentric washer type not the shims) what else would you guys check to make sure all bases are covered, alignment shop tells me that the right side (passenger) is at fault. Adjustment is available on the driver's side only. This is 2013 Volvo vnl day cab.
    Thanks in advance
  3. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I don't know but I'm very curious as to how they can only adjust one side. Something does not sound right there.
    Maybe the chatter is Tire scrub when you turn left?
    Your truck needs to be aligned properly or it's going to cause you all kinds of problems aside from the problem you're having.
    Snailexpress and spindrift Thank this.
