Drive Thru It Or Shut It Down?
Discussion in 'Other News' started by mjd4277, Feb 21, 2018.
  1. mjd4277
    mjd4277 Road Train Member
    14,736
    45,391
    Oct 4, 2015
    Fitchburg,MA
    x1Heavy, skellr and dan31186 Thank this.
  3. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Just another day in paradise. :D
  4. dan31186
    dan31186 Light Load Member
    97
    181
    Jan 30, 2017
    Cincinnati, OH
    That doesn't look very fun. I wouldn't really want to stop or keep going.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    More common than you think out there...
    It can be just fine from Calgary to within 10 miles of where 2 and 3 meet. Then it's windy as all hell and iced over. You don't have an option to stop. Earlier on...sunny and light wind behind you.
    I like to take 2 south to 3 rather than jump over to 22.
    It happens...
    not4hire Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Those skirts did not help.
    Save a few dollars fuel they said. Flopsie in the wind very easy peasy to total the whole #### truck and load.
    Im telling you those stupid stupid freaking skirts on them trailers are NOT worth it.
    Driver did one thing wrong. Going out into a high wind warned area in the beginning.
    What he did do is stop. And consider the problem. I see the ground is frozen and that the wind is constant strength right to left. I would have pointed into it with a slight upslope to help getting back onto the interstate when the winds die down after a while.
    It conflicts with my own experience when you are very cold with winds like that. You point the trailer into it to protect your engine's heat output to stay alive.
    I don't know.
    Whatever I write will be contested in one way or the other. That driver should not have gone out. HOWEVER in redemption he did display a willingness to reduce loading on his rig by actually stopping to think things over. But that stupid skirt has to go. It's a liability here.
  7. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Side skirt makes little to no difference in how the wind will or won't pick up a trailer... the weight of the unit is the biggest factor.
    Yes I understand if you're in a hurricane if you open the house windows you lesson the resistance...
    It's also known if you lower everything the wind is forced to go over top. So which engineering argument wins?
    Side skirts will save you .25 to .4 mpg (us gallons) depending how far up your trailer tandems are. That's a measurable roi unlike a lot of other things sold as fuel saving technology but in reality is just snake oil. Do they look kinda dumb? That's another debate.
    If you say "the driver should never have left out" you've never been to Alberta in the winter. With that thought process you might as well do all your trucking there from June to September. Places to stop are few and far between and the weather can and often does change in the time you leave out before the time you get to the next town.
    special-k, not4hire and bzinger Thank this.
  8. bzinger
    bzinger Road Train Member
    16,653
    66,168
    Dec 10, 2014
    omaha , ne
    A lot of people from lower latitudes don't understand how the wind and blowing snow will glaze a road even on a sunny day .
    I 94 from from Barnesville mn into Fargo is very prone to it .
    Grab the shoulder and pray .
    uncleal13 and not4hire Thank this.
  9. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    People only think Wyoming is windy because they've never been to Pincher Creek. o_O
    uncleal13, gokiddogo and bzinger Thank this.
  10. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    That's an easy part of 94
    My nemesis is Montana's part of 94
    Nobody around
    Windy
    Some good hills and curves
    Need the A game there
    Ran it all winter..... for the sole reason I didn't want more states than necessary on my ifta at quarter end lol
  11. bzinger
    16,653
    66,168
    Dec 10, 2014
    omaha , ne
    Lots of areas prone to that ...29 from Fargo to Winnipeg brings back memories too.
