Drive tires
Discussion in 'Ask An Owner Operator' started by 4255deere, Dec 22, 2016.
  1. 4255deere
    4255deere Bobtail Member
    I am going to replace my drive tires, They are Bf Goodrich DR 444 In a 275/80 R 22.5 Saw a Guys tires this summer they were Made in china, Lots of tread I don't remember the name of the tires but they looked good . The Goodrich tires were good but is there some thing much better, I drive mostly hiway but some rock roads
  3. mslashbar
    mslashbar Medium Load Member
    604
    822
    Jul 22, 2009
    elizabeth,co
    Michelin XDN2, expensive but you get what you pay for.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    We have had goodyears fail on our cars. One did not make it past 22K.
    Go with Bridge Stone, Michelin (Never ever had one fail. ever.) or even Yokohama.
    Get the most tread you can find for a big truck. What's it? 32/32 or something these days?
  5. sawmill
    sawmill Road Train Member
    3,953
    72,440
    May 29, 2015
    Evanston, WY
    Thick tread does not necessarily translate into longer life. At one time I was getting more life out of some trailer tires that started out at 18/32 than the ones that started at 24/32.
    I run Goodyear G282 drives. Not because I wanted that particular tread pattern but because I got a smokin' deal on them. They are wearing much better than a chinese tire would. You get what you pay for.
  6. kitCat
    kitCat Light Load Member
    97
    38
    Oct 13, 2013
    I used to run Michelin now I run Continental, they are almost the same price Continentals maybe $20 cheaper. I like Continental lot better than Michelin
    stayinback Thanks this.
  7. AModelCat
    165,049
    Chinese tires are usually oval.
    nax and Lepton1 Thank this.
  8. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    If you run a lot of off road, does that change your choice of drives?
    When you change your drives do you balance every tire? To me this seems like a no brainier, but I have talked to a couple of owners that say they only pay to balance steers.
    x1Heavy Thanks this.
  9. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    Off Road means cross rib drives. Whatever brand they might be. Anything else is simply inadequate for that work.
    Lepton1 Thanks this.
  10. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    No sense balancing tires unless you like equal, however you spell it. The brake drum will throw everything out of wack. Better to use centramatics or balance masters.
  11. m16ty
    m16ty Road Train Member
    2,274
    4,964
    Jan 22, 2016
    One bad thing about Michelin tires is on some trailers and such that sit a lot, they tend to dry rot before other brands. This really only applies if the tires get quite a bit of age on them before they wear out or carcasses of recaps. It must have something to do with their rubber composition.
