Drive without service brake?
Discussion in 'Ask An Owner Operator' started by Ikamob01, Oct 24, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    I'm having problems with service trailer brakes leaking somewhere. Can I just block the entire blues line and drive it to the mechanic 8 miles downtown the road?
  3. AModelCat
    164,674
    Legally no. Too many inoperative service brakes.
  4. Ikamob01
    314
    195
    Dec 4, 2021
    Of course I know that but will it work?
    Rideandrepair and OLDSKOOLERnWV Thank this.
  5. D.Tibbitt
    157,120
  6. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Youll obviously have far less braking power, so. If loaded, use extreme caution. Had a cold winter and the blue line snapped on me at a shipper before (well, the red, but i swapped lines to get to a truckstop and replace the line, the drive was fine, but easily needed 2x the braking distance)
    Tb0n3, RJM1953, tscottme and 4 others Thank this.
  7. OLDSKOOLERnWV
    19,140
    289,410
    Yea it will work but not legal so be safe and make good decisions if you’re loaded.
    I carry an assortment of pipe plugs and caps for this very reason….
    86scotty, Brettj3876, Bean Jr. and 3 others Thank this.
  8. Crazytrucker77
    Crazytrucker77 Heavy Load Member
    848
    1,048
    Nov 23, 2014
    Grants Pass, OR
    Don't do anything to the line just put the carriage bolt in the hole in the brake boosters and it will release the brakes. Make sure to tighten it as much as you can.
    tscottme Thanks this.
  9. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    There is no need to cage the spring. The spring brake side is fine. He said the service side was leaking.
    If the trailer was empty, I'd drive it the 8 miles very carefully. Loaded? Only if it's very flat ground and not a very busy road... slowly with flashers on.
    RJM1953 and Opendeckin Thank this.
  10. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Does a mobile mechanic really cost that much more than a shop? In my experience it's worth it just to get the mobile guy out there.
    77fib77 Thanks this.
  11. The Crossword Trucker
    The Crossword Trucker Road Train Member
    1,172
    2,333
    Feb 21, 2015
    If you work for a mega , dont do this
    If its your truck and you are empty or light, then you might consider it.
    86scotty and Tb0n3 Thank this.
