Driver Extreme
Discussion in 'CB Radio Forum' started by sts7925, Nov 28, 2022.
  1. sts7925
    sts7925 Bobtail Member
    5
    Nov 28, 2022
    Anyone have any experience with Driver Extreme Silver Bullet antenna? Is it a good option or stay away? Thanks
  3. Deadwood
    Deadwood Heavy Load Member
    789
    2,296
    Dec 24, 2016
    It worked for me. The bottle says the erection would only last for an hour but three hours in, I decided to put my car keys on it so I wouldn’t lose them.
  4. sts7925
    5
    Nov 28, 2022
    You're a lot of help
  5. Night Stalker10
    Night Stalker10 Road Train Member
    1,699
    1,271
    Jun 26, 2017
    I had never heard if this antenna. So I did a search on the web and of course it brought up gun ammo. After searching I finally found a link for this antenna. My first thought was it appears to be well built and I like the design of the tuning stub. About the only thing I didn't like was the tri-band part. Usually an antenna for the 11 meter band performs better as a single band antenna. If you decide to buy one, maybe you can report back with your experience and thoughts about it. Also don't buy an antenna shorter than 48 inches or the performance suffers.
  6. sts7925
    5
    Nov 28, 2022
    I did buy one, 66 inches. I'll report back when all is installed and tuned. Thanks
  7. Ridgeline
    22,774
    124,527
    It is a knock off of a Paladin antenna (think it is the space antenna model) from the late 70’s, except this driver extreme version is claiming to be a replacement for the factory multiplexed antenna.
    It should work if it isn’t multiplexed with the am/fm radio or anything else.
  8. Night Stalker10
    1,699
    1,271
    Jun 26, 2017
    That's what I was thinking. If he uses it for a CB antenna only, it should work just fine.
  9. Xcis
    Xcis Medium Load Member
    497
    269
    Jul 9, 2008
    Bridgeport, Pa
    If you are not using an amplifier, the watt rating of an antenna means absolutely nothing.
    . For an amplified setup, the antenna is probably ok.
    . With no amplifier, a Francis CB-26 is the same length at a much lower cost. You decide.
  10. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,317
    Jun 10, 2019
    Yea I always laugh at those HUGE CB antennas that truck stops sell that say they are good for up to 5000 WATTS!!!! Wow, and most guys push 4 watts through them.
  11. Neverready
    Neverready Medium Load Member
    406
    330
    Jul 24, 2014
    Pocomoke City, Md.
    Running a 66" version on a 2023 680 KW. Singled out drivers' side, SWR 1.2 using external antenna analyzer. If I can get someone to pick up the microphone don't seem to have any difficulty in conversation, no amp. 6ft skipshooter came in at 1.4 SWR. It is fairly thick but haven't had ice build up on there yet to see how it holds up to the added weight and wind load. Had good luck with the 5.5ft Francis but they don't hold up with a heavy ice load.
