Drives over by 400lbs.
Discussion in 'Heavy Haul Trucking Forum' started by Hegemeister, Jul 24, 2018.
  1. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Loaded at shipper, chained and tarped, (a lot of work!) drove about 20 miles to a truck stop and scaled.
    I am permitted for 40,000 on the drives and the scale measured 40,400.
    Would you run it? Or go back to the shipper and spend a half a day doing the job all over again?
    By the way, I'll be running Kentucky.
    Would you reorder Kentucky permit and add 500lbs? Also my drives are rated at only 40K.
    Macneil Thanks this.
  3. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    Run it, no one will notice that especially on a rolling scale.
  4. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Nice to hear. Especially coming from you. I'm Beat. Thank you!
    Oxbow, BigBob410 and johndeere4020 Thank this.
  5. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
    Run it hard and fast burn up the fuel
    Hegemeister Thanks this.
  6. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    I know, but half the weight of the fuel is on the steers. I might only knock of 100 lbs by the time I hit the Kentucky scale.
    Oxbow Thanks this.
  7. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    At 7 lbs per gallon and 6 or so mpg you lose around a pound per mile or a tad more. How far is the next dot scale ya gotta cross? 250-300 miles? Yeah, run it. 20 miles....maybe not.
  8. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Remember, the tanks weight is shared by the drives and steers. So maybe about 1/2 lb or so per mile. Right?
  9. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Slide your seat forward two notches.
    I think 3lbs per gallon coming off the drives should be safe bet. Conservatively.
  10. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
    Move equipment out of your headache rack. If you can.
    My extra chains, binders tarps..moved about 300# snow chains also.
    I had an empty box on trailer.
    Good luck.
  11. shogun
    shogun Road Train Member
    6,075
    72,162
    Jan 23, 2009
    Doing a regen
    Misread the title. I thought it said drivers over 400 lbs, I’ve seen plenty.
