Driveshaft question 2017 Pete 579
Discussion in 'Trucks [ Eighteen Wheelers ]' started by stark21, Dec 12, 2020.
  1. stark21
    stark21 Light Load Member
    129
    5
    Jul 25, 2010
    Virginia Beach
    I was recently greasing up truck and when I got back to house after driving it, I noticed grease on airbags and on the ground.. I assume that is normal when you fill it with new grease. but here is a pic of rear of driveshaft. it's first peterbilt I owned and just making sure its normal.
  3. AModelCat
    164,674
    How much did you pump in there?
    Yes its normal for the slip yokes and u-joints to sling a little grease. Looks like you might have put a little much in there though. Better than undergreasing at least.
    spsauerland Thanks this.
  4. stark21
    129
    5
    Jul 25, 2010
    Virginia Beach
    I filled it till I saw just a little coming out, since I wasn't sure when last time it was greased, I thought it was ok as you said better to have too much then to run dry.
  5. AKDoug
    AKDoug Medium Load Member
    323
    802
    Mar 21, 2018
    Check to make sure you don't have a grease zirk with a ball that's stuck. Poke 'em all with a sharp pick. If you do have one it will allow the grease to fly out that you just put in there. Usually you see them ooze right after you remove the grease gun, but not always.
  6. stark21
    129
    5
    Jul 25, 2010
    Virginia Beach
    checked them all and nothing is stuck as I didn't see anything come out of the zirk.. but will keep an eye on that.
